Cabin air filter
jarred52
Today, I installed the last of my cabin air filters that I bought from Rock Auto and it's now time to order more. These were regular paper type filters. Has anyone used a carbon-charged filter? If so, any noticeable difference or problem?
Thanks!
The carbon filters may be fine, but I would in general be careful that the airflow rating is the same as the OEM filters. Just like home HVAC filters, some people don't realize that the filters that trap the most particles also cut down on airflow and make the fan motor work harder than it is designed to do. Obviously, keeping the filter fresh also increases air flow.
Thanks!
My experience with "fancy filters" of any kind is: Don't waste your money.
Also, they can impede air-flow. Can cause big probs.
For what it's worth - I'm EPA certified for both mobile & stationary units.
Thanks, guys; I'll stick with what I've been using.
The cabin filter made of paper is supposed to trap dust and dirt particles. Adding carbon only neutralizes odors. If you do not drive in a smelly area it is a waste of money.
Advance Auto Parts is (was) selling a very good cheap paper filter made in Korea. The box was a misprint, showing an activated carbon layer, when in fact, it had none.
Can someone pls post a link to a air cabin filter to buy online. Thanks
The cabin air filter is one part where it is not that important to use the Hyundai OEM version, assuming that it is not too restrictive in the airflow. You can try AutoZone and Advance Auto Parts websites. The will ship to you, or you can order online for pickup in the store.
I just installed the Fram arm and hammer yadda yadda carbon filter and it seems to perform well. Not that my car smelled "musty" or something, but it smells better now. I just got a genuine hyundai carbon filter, because why not, but it is even sturdier than the fram, which is saying something because cause the fram is pretty stout. anyhoo, the fram seems fine for now, no perceived reduction in flow, which is as mark88 pointed out something to keep in mind. by means of example, most P2 volvos CAN actually use two filters, but you never should do so which is why the block one with a tab at the factory, the fan is just pushing against a brick wall and dies an early death.
link to the fram carbon currently using - https://www.amazon.com/CF10735-Fresh-Breeze-Filter-Hammer/dp/B004M7VF2O
link to genuine hyundai carbon will use next - http://www.ebay.com/itm/182498567423 (thats the people i actually bought mine from, packed well shipped quick)
as always, jm2c
I also use the fram posted above. As far as density, i always put the burden on the motor. Blowers can be replaced but lungs can not. I'd rather reduce the life of the motor and will happily replace the part.
