Can anyone help? On 2015 Genesis 3.8, when I closed the passenger side window and turn off the engine it shows window open but its closed.
ElphieSJ
Could be the sensor anyone has experience on it and fixed?
The manual has instructions on how to reset windows. I'd try that first, though it could be a sensor.
To reset the power windows
If the power windows do not operate
normally, the automatic power window
system must be reset as follows:
1. Place the Engine Start/Stop button
to the ON position.
2. Close the window and continue
pulling up on the power window
switch for at least one second.
properly after resetting, have the
system checked by an authorized
retailer of Genesis Branded products.
The manual has instructions on how to reset windows. I'd try that first, though it could be a sensor. To reset the power windows If the power windows do not operate normally, the automatic power window system must be reset as follows: 1. Place the Engine Start/Stop button to the ON position. 2. Close the window and continue pulling up on the power window switch for at least one second. If the power windows do not operate properly after resetting, have the system checked by an authorized retailer of Thank youGenesis Branded products. The manual has instructions on how to reset windows. I'd try that first, though it could be a sensor. To reset the power windows If the power windows do not operate normally, the automatic power window system must be reset as follows: 1. Place the Engine Start/Stop button to the the problem.ON position. 2. Close the window and continue pulling up on the power window switch for at least one second. If the power windows do not operate properly after resetting, have the system checked by an authorized retailer of Genesis Branded products. The manual has instructions on how to reset windows. I'd try that first, though it could be a sensor. To reset the power windows If the power windows do not operate normally, theThank you. For some reason this solved automatic power window system must be reset as follows: 1. Place the Engine Start/Stop button to the ON position. 2. Close the window and continue pulling up on the power window switch for at least one second. If the power windows do not operate properly after resetting, have the system checked by an authorized retailer of Genesis Branded products.
Thank you this asolved the issue ctually
  • Like
Reactions: EdP
