Can anyone please help 911!!
Speedy6988
I have a 2009 3.8 sedan. Never had an ounce of trouble with her. All the sudden radio no sound couple days later no screen now tonight she's left me stranded in Omaha, Ne. Went to start to leave and nothing but a sign on the dash that says check steering lock?
First thing I'd check is the battery, cable connections and ground connection. Are lights working?
If battery is good and connections are good, I'd call a tow truck.
Ya that's what I went through first all fuses also.
does power steering work? if not check alternator. does it click or try to turn when it start? if it click then the starter might be dead.
How old is your battery? Battery voltage when car is off should be over 12. Check connections to battery and alternator. Check battery voltage while the car is running, should be 13-14 volts.
Features of your vehicle
D150410ABH
Press start button while turn steering
When the steering wheel does not unlock, the warning illuminates for 10 seconds on the LCD screen.
D150411ABH
Check steering wheel lock
When the steering wheel does not lock, the warning illuminates for 10 seconds on the LCD screen.
D150412ABH
Check stop lamp fuse
When the stop lamp fuse is disconnect- ed, the warning illuminates for 10 sec- onds on the LCD screen.
Replace the fuse with a new one. If that is not possible you can start the engine by pressing the engine start/stop button for 10 seconds with the ignition switch in ACC.
Type I
Type I
Type II
Type I
