Can the power steering be adjusted?
Kon
7
I love everything about the Genesis except the steering, it's much heavier than every other car I've driven and makes driving needlessly difficult. I wouldn't mind heavy steering in a sports car where road feel and extremely precise control is important, but it makes no sense in a luxury sedan like this.
Is there any way to increase the power steering assistance so the wheel doesn't feel so heavy?
Mr. Incredible
2,043
688
Genesis G80 Sport
Heavy steering is usually the result of low tire pressure.
I don’t experience this in my 2018. In fact the steering in my g80 is a bit loose/light for my tastes. Better in sport mode but still not as tight as my RCF.
Kon
7
I double-checked the tire pressure yesterday. Dash was already saying 33 all around (increased a couple PSI after driving for a while) and I stopped at a gas station with a digital air pump just to be sure.
I've read that some vehicles like the Sonata have a service menu for adjusting power assist level, guess I'll give the dealer a call and see if the Genesis has anything similar.
Mr. Incredible
2,043
688
Genesis G80 Sport
Been discussed a lot on this forum 33psi is way too low for a vehicle of this weight. Try 36-38 psi cold outside air temp around 70 and after car has been sitting 5-6 hours.
You will find handling and steering to be a lot better. Ride might initially feel a bit firmer, but personally I didn’t notice it.
And no there is no menu item for this.
Kon
7
Can't hurt to try I guess. I'd read through a few tire pressure threads on these forums and the consensus seemed to be that we should just trust Hyundai's recommendation.
While we're on the topic of tires, is there a specific set that's recommended for the 3.8 AWD Genesis if your goal is comfort rather than performance?
Mr. Incredible
2,043
688
Genesis G80 Sport
Look for tires labeled for TOURING. Those will provide the most comfortable ride. Just be sure they are properly rated for the weight of the vehicle.
popular models of touring tires include: Michelin Defender, BFGoodrich Advantage T/A, and Goodyear Assurance ComforTred Touring.
I prefer the BFGoodrich. I’ve run them on several cars and trucks. My wife currently has them on her 2017 Camry and loves them over the Bridgestone tired the car came with, she says they are quieter and the ride is more “floaty” which is her preference over mine, which is firmer and more performance orientated.
We’ve had good luck with the BFGoodrich tires lasting well past their warranty and neve had any defect issues. They also have Better traction in rain and on slick roads over Goodyear and bridge/fire stone brands IMO. Especially on the trucks I’ve had them on.
EdP
Supporting Member
SUPPORTING MEMBER
4,451
1,441
Parrish, FL
carguy75
286
63
Atlanta, Georgia
I set my tire pressure at 34 psi front and 36 psi rear cold and the handling and steering works well for me. The tires heat up to about 36psi front and about 38psi rear while driving per the tire monitoring system.
To my knowledge the steering ratios and assist is set by the factory. You can only change the steering assist by selecting drive modes I believe.
Kon
7
As for tires, do you want a summer, winter, year round tire? I was very happy with Nokian WRG3 on my last two cars. They have a true snow rating yet can be used all year.
I live in the Northeast but really just want comfort above all else -- I can drive my SUV to work on the rare snow day we get around here.
