Can't load my CDs
gigum3
I can only load one CD. How do I load my other 5 CDs? Any help would be appreciated.:o
If you have the ultimate package, there is no CD changer. Only one CD can be loaded at a time.
You can copy your music to the "Jukebox" which has 30gb of user space. I have several hundred songs in my Jukebox already and will probably double that number as time goes by.
Thanks Pahaska
Where do I find the Jukebox? Sorry for being so dumb :(!
Can any type of file be loaded on the jukebox (MP3, lossless)- is there a limit on the resolution size?
Thanks Pahaska
Hit home, then media or hit the media button. Jukebox should be on the top of the stack, then USB. I think CD was under USB in the list. I haven't tried to load files off a CD. You can not rip music to the Jukebox.
When a song is playing, hit Menu and on the right is the option to copy that song or the whole album to Jukebox. The files I copied there are WMA files that I ripped with the slider at the high fidelity end. I think MP3 works as well. When you load a USB, include the cover jpegs as well. The display will show the album cover while playing.
Mp3, wma only. for mp3 bit rate from 128-320 or vbr. Im not sure of wma.
After your music is loaded you can hit the voice recognition button on the steering wheel and after the beep just say "Jukebox Music". Assuming you have your voice settings set for "expert" mode you will not get any prompts and the music will start playing. From there track manipulation is done with the "Media Global" commands such as "Track 4", "Repeat" and the rest of the commands that are in the DIS manual under voice commands.
