Can't locate squeaking /
Pearlturbo
Genesis GV70
Ok so I think the sqeaking started after I did just front brake pads, didn't replace the rotors (all work done at dealership)
The sqeaking is coming from the front, where I have no idea. The noise happens when going over bumps, uneven road surfaces, and sometimes highway driving with the road surfaces. It's really annoying, loud and embarrassing.
So long story short, dealership said my rotors was fine and didn't need to be resurfaced or anything. So I didn't do rotors on the car just replaced the pads. Shortly after, maybe week or two the noise starts, just a coincidence? Maybe... So I complained after they did the brakes the noise has been there. They test drove the car and duplicated the noise. They relubricate all parts on caliper and everything.. So driving home the car STILL making that high pitched sqeaking over bumps etc. so I call and say it's still making the noise so they now say maybe it is the rotors and I should just replace them. Sooo I went and bought OEM rotors ( I have the rspec model) 320 dollars later for rotors, I get them installed...
No noise at first, then it starts making the noise AGAIN. So now I'm aggravated because I spent all that money on rotors and the problem isn't resolved.
I don't know what kind of brake pads they used on the rspec but I got coupons in the mail from my dealership saying 100 dollars for pads and install. Since I needed it bad I jumped on this deal. What kind of pad they used I have no idea. Maybe it's the pads? I don't know just sounds like it's squeaking on metal. Very hard to diagnose, anyone have the slightest clue of what it could be?
*They also said suspension is fine, nothing coming from suspension, or anything along those lines.
13' Genesis rspec 5.0 w/58k
I would take the car to another dealer as a warranty item and see what they say. If the original dealer used some cheapo pads, or did not install them correctly, the other dealer might be able to see the problem.
Check the inner dust shield behind the rotor - could be bent and making occasional contact with rotor in motion.
I had a loud squeak with my 2012 5.0, that would occur over every bump or dip in the road. From the cabin it sounded like it was in the front right suspension. I checked all the suspension components and found nothing. Then I leaned on the back corner of the hood and heard the squeak. The root cause turned out to be the point near where the hood hinge attaches to the body. There are several metal surfaces sandwiched together at that point. I loosened the back of the fender and sprayed silicone spay into that area, and problem solved.
So I think I'm going to be replacing the pads, car only does the noise when the brakes are hot. I already replaced the rotors and that's not the problem. So I'm going to buy Hawk semi-metallic brake pads and resurface the rotors and hopefully that solves the high pitched squeaking.
With the new rotors and old pads, the way the rotors are currently looking, somethings not right. I think it's a really cheap pad the dealership installed in March. They're saying it could be debris from the road stuck on the pad and such🙄 Idk
Happens all the time, they ding it with the wheel or their hands and then you get the scrapping noise under certain conditions
