GreasedMonkeys
- Oct 16, 2022
- Genesis Model Year
- 2019
- Genesis G70
Approximately once a month my iPhone will be playing music or podcasts and navigating (normally Google Maps), then it will randomly disconnect and not reconnect. I try to unplug/reply the iPhone at the base of the phone and it does not reconnect. I try to unplug/replug the iPhone cable from the USB port below the screen, but it does not reconnect. My custom (star) button is programmed to open Phone Projection, so when I press that (without the iPhone reconnecting on its own), I get the following message: “Android Auto and Apple CarPlay are the supported Phone Projection options. Enable the option to be used, then connect a phone that supports Android Auto or Apple CarPlay using an approved USB cable.” It gives me two options: “Settings” or “Close”. If I hit Settings, it crashes (both while driving and when I pull over and put it in park). I try shutting down the iPhone and restarting, which doesn’t work. I try pulling over, turning off the engine, then turning it back on, which doesn’t work. The only thing that seems to work is to turn off the engine for at least several minutes and it reconnects, which is not a good solution if you’re pulled over on the side of the road or if you need the map for directions. I have a 2019 G70, Standard-class Gen5 Navigation, iPhone 12 Mini, iOS 16.0.
