First Generation Cat delete and exhaust "leak".
TheDr9669
Greater Houston area
I have had the MSA cat deletes on for a bit over a month now and am just now getting a video put up. When I put the deletes on I developed (created) an exhaust leak. It is 100% reversible and was wondering what you guys thought.
Video on the tube
It says "This video is private" - can't watch it.
With just the cat delete alone there is no discernible increase in exhaust sound - had cat deletes on four Genesis and now on my Equus.
I bought a set of used MSA secondary cat deletes from a member here and also found that they had audible exhaust leaks at the bolt holes. It took a ton of trial and error but with a different set of bolts I was able to eliminate the leak by tightening it just right. Its a bit of a pain for sure but you can probably fix it.
I think I might have been misunderstood just a bit with the exhaust "leak". I intentionally created the leak as an experiment to goof around since I was under the car putting on the pipes. I originally had no intention of keeping it setup that way, but have since then gotten lots of compliments and questions about the car. I was wanting to get some fellow Genesis owners opinions on the sound.
I guess the video from the inside is not the best. I will try and get a video up from the outside to give better perspective.
Oh I see, you're asking what we think of you creating an intentional exhaust leak on your top spec Genesis Sedan. I could use a string of unkind words but I'll just leave it at a bad idea. It falls expressly under the category ghetto mods.
