Change or fix buttons around center dial
OUsig
McKinney TX
hello all
Some sticky liquid was spilt on the center area and got down behind the buttons. Now the ones on the passenger side are nearly useless as if you push them down they barely come back up. and dont if it is cold (like now).
So has anyone taken the center area apart? I was planning on doing that then cleaning out behind the buttons.
hello all
fyi to anyone else
use plastic pry tools
take off the trim around the cd player
then hai g your hands, lightly pull up from under the cd player then use another pry tool to pull up the rest of the trim.
be careful to note the plugs and the screws you will be taking out.
long story is the buttons on my center area sew clean and smooth finally! it takes a bit to clean out the buttons and the rubber backing but it. is worth it
