Changing the dual HID bulb to dual LED
Zohirulnyc
Replacing a single HID bulb cost around 250-300$ from the dealer. I wanted to ask if anyone ever replaced their HID bulb for led.
Much of that cost is labor. Additionally, our cars use D1S bulbs that are also more expensive because they include the igniter (metal box at the base of the bulb). Replacing the bulbs requires removing the front bumper. You'd still need to pay for labor or do the work yourself even if you bought LED bulbs. The light source on LED and HID bulbs is shaped differently, resulting in a different beam pattern from the projector. You could end up with an ineffective or dangerous beam pattern if you put LED bulbs into a HID projector, which would then require more money and work to replace them again.
If you're going to spend the time and money replacing them, I recommend either the Osram Xenarc Night Breaker Laser or, if you prefer a higher CCT, the Philips X-TremeVision gen2. The Philips XV2s are rated at 4800K and, from what I've seen, are pretty close to pure white without appearing excessively blue or yellow. Wherever you buy them from, be aware that there are a lot of fakes on the market. Both bulbs have a code on the box to check for authenticity.
Check out the retrofitsource for bulbs. They do a lot of in-house r and d, and they have d1s bulbs.
