Clock issue on Radio / Nav Screen '18 G80 Premium
PeterPNJ
12
Hi All,
I noticed in the past few weeks (and I tried searching the forum, but either nobody else has brought it up or I am searching incorrectly), that when starting the car, the clock on the radio/nav screen reads "--:--" rather than a time. The time will then kick in within 15-20 seconds, but it has sometimes taken up to 2 minutes and one time it was 8 minutes. When I first got the car, the time would pop up right away. I just recently had a service, so I don't think it serious enough to go back just for this, but wanted to hear some opinions.
The first time it happened, I thought maybe some sensor was hot because the car was sitting in a park & ride all day in the sun and 95 degree heat. However, it's been happening day or night without regard to temperature.
Is this a known issue? Any ideas what might be going on? I will bring it up next time I am at the dealer, but any help would be appreciated.
Thanks!
Peter
EdP
Supporting Member
SUPPORTING MEMBER
6,510
3,080
Parrish, FL
PeterPNJ
12
There are multiple threads about the clock not working about a week ago. Not were the same as yours though, but could be related. I'd try a radio reset first. Use a paper clip or ball pen inserted in the small hole on the front panel. Hold it a few seconds. It is just above and to the right of the CD slot.
I will give that a shot after work today. Thanks!
WPB
39
Florida
Do you have your clock set to get the time from GPS? That's the way I have mine set. In my garage I don't get a strong enough GPS signal so clock is often blank until I back out.
PeterPNJ
12
I do have it set to GPS time. However, wouldn't it retain the time from the last time I shut the car off? Also, in my case the car has been left outdoors for the past few weeks.
Mcc
Supporting Member
SUPPORTING MEMBER
2,867
642
Los Angeles
Genesis G90
WPB
39
Florida
Besides the clock is anything else wonkey? Namely does the map work when the clock is not working. Maybe a bad or loose antenna connection in the "shark fin" antenna circuit.
Pedal Commander
