Thanks for your reply, I see two a 60 and a 100 which one did you change, Thanks again RobReplace the visible link box on the positive battery post
I should have said 80 nd 100, where did you find these fuses, local dealer said you cant buy them, parts stores toThanks for your reply, I see two a 60 and a 100 which one did you change, Thanks again Rob
These fuses usually are not the issue. They can be sourced on Amazon from Blue Sea if you really want to replace them, called MIDI/AMI fuses.Did you end up replacing this and has it worked?
The most likely cause is your positive battery ring has worn out and
This issue will be fine for months... then reappears as is worse when stealing wheel is turned fast when stopped or almost stopped. I can't see why that would lead to the battery ring. So frustrating... been chasing this for 4 years nowThese fuses usually are not the issue. They can be sourced on Amazon from Blue Sea if you really want to replace them, called MIDI/AMI fuses.
The most likely cause is your positive battery ring has worn out and doesn't maintain contact correctly.
Yeah. That makes sense. Will give that a go. Thanks for the follow-up.What you are describing is the ring terminal being defective. If your power steering is shuddering, car electronics cutting out or otherwise not working perfectly, you have a battery power problem. The terminal has little teeth that are supposed to engage the battery post, but after years of vibrations and large power draws they break down and the terminal will never be able to tighten enough. The easiest solution is to replace the terminal- a $20 part but some modification may be required because what you can source will not be the same as what's in the box (Hyundai sells it for $1400).
Your power steering runs off the battery, not the engine. It also does not go through the fuses on the battery, it goes down the big fat cable to the front of the car.
Improved positive battery terminal box
By improved, I mean liberally butchered with a rotozip. But hey, my car no longer dies without rhyme or reason... and remote start works again. Exhibit A: pot metal terminal made by Hyundai and sold for $1400 Exhibit B: pot metal terminal made by Hyundai for $14. Of superior design...genesisowners.com
The battery terminal carries weight of anything in the trunk. So adding copper wrap just makes it slip more frequently- and the conductivity of the foil isn't high enough and causes more arcing. The power steering is a constant surging 100+ amps of current draw at low speeds and any inefficiency shows up quickly.@Suburbazine - did you try adding some metal to the OEM part to help with the slack before swapping out the entire terminal? I wonder if some copper around the battery post would suffice
