Coolant leak 2009 4.6
Tisho_75
Имам нужда от помощ. Някъде има теч на охлаждаща течност. Дали е от маркучите на отоплението или някъде под тях?
I need help. There is a coolant leak somewhere. Is it from the heating hoses or somewhere underneath them?
Need more information. Do you see the coolant anywhere? Could be hoses, could be the coil.
Нуждая се от повече информация. Виждате ли охлаждащата течност някъде? Може би са маркучи, може би е бобината.
Not a Genesis, but the plastic heater hose couplings at the rear of the engine failed last year on my 2007 Santa Fe @ 220kmi. Had them replaced by my trusted local independent mechanic for a few hundred dollars and all was fine after.
Plastic coolant components = bad compromise for long-term reliability. Expect them to fail as cars approach 20 years old or 225-250kmi.
