Cruise control issue
KDX
147
43
I was driving down the highway today and the cruise control would beep a few times, apply the brakes, take me down to 90kph and then take me back to 120kph where I had it set. After doing this a couple of times I turned off the cruise, turned it back on and I got this message. Sorry about the crappy pic.
I shut the vehicle off when I stopped for shopping and it did the same braking/slowing down to 90kph and then accelerating back to the set speed. I didn't hit that many bugs on the road today so I don't think that was the problem. I also tried changing the car space interval from the furthest away to the closest and it still malfunctioned. The only time my CRV has shut down the adaptive cruise control is when there is a build up of ice on the front sensor. Any ideas as to what could be the cause of this problem?
EdP
Supporting Member
SUPPORTING MEMBER
3,517
823
Parrish, FL
I assume there was nothing in front of you when it slowed you down. Could be a bad sensor or something as simple as a loose connection. Definitely not normal. Only time mine shuts down is snow or heavy rain when you should not be using CC anyway.
KDX
147
43
There was no traffic in front of me. I'm guessing you are probably right about the loose connection. I'll go poke around under the hood later.
devellis
179
43
North Carolina
No Genesis Yet!
Again, these are the sort of annoying little things that can show up on a new model. This sounds like it should be a relatively easy fix, once they find the source. A loose connection is certainly a possibility. It should get straightened out fairly easily.
Hopefully yours is an isolated incident and this won't be a recurring problem. More generally, small issues seem to be popping up here and there on the cars that have been delivered. These issues are typical on the first run of a new model. Hopefully, they're not commonplace but just show up infrequently. The headliner noise issue, which apparently appeared on the Korean-spec cars as well, is a bit more worrisome in that it's happened repeatedly and is potentially harder to resolve. But hopefully, they'll figure out the sources of these gremlins in short order and be able to fix them quickly and permanently.
WhoIsHomer
34
Edmonton
I got the same error message when trying to turn on cruise. I was on a highway with no traffic. It was dark out not sure if that was a factor.
Ojfox
12
Toronto
I get this error message when I try to initiate the cruise control by flicking the switch up towards the "RES +". It seems to only initiate if pressed down towards the "SET -". After it's initiated, then the speed can be changed.
KDX
147
43
On page 5-123 in the owners manual it tells you how to switch from smart cruise control to regular cruise control. I will try that next time I'm out on the highway and see if it gives me any kind off error message or behaves erratically. I let my agent know yesterday and he said he would be making some inquiries on my behalf today. I went to the Genesis Canada website and reported the issue though their contact link.
Edmguy
139
43
Edmonton, Canada
This. Flick down, folks!
For the message, I had the same thing a few times before I noticed I was trying to flick up and not down.
As for the cruise braking and then speeding back up, I haven't had that issue unless someone was in front of me. Hopefully something simple like a loose or dirty sensor.
KDX
147
43
Went for a 40km drive tonight with no issues. There was one connection behind the front sensor that seemed a little loose, maybe I fixed it, maybe not. Wait and see. I took these pics while I was driving.
NurburggreenG70
10
Yes for sure. Must set first. One of the conditions needed to be met is the max speed being set. If u tap res first it no work
Slip_Angle
87
Winnipeg
I had the problem as well. Cruising down the highway with cruise set to 105 kph, not a car in sight and suddenly it would slow to 80/90 or something like that and then figure out nothing there... back to 105... Genesis took it in right away, re-calibrated/re-aligned the radar and all seems good now.
Mr. Incredible
1,470
395
83
Genesis G80 Sport
turning the cruise off wipes the memory, you can't "resume" until you set. hence the alert.
This alert will also pop up if you are using SCC and allow it to come to a full stop in stop and go traffic and the alert to tap the gas or resume comes up and apply the brake, which will cancel cruise control, it will then pop this alert not resume (at least on the G80) until you are over 10mph.
Slip_Angle
87
Winnipeg
Problem has returned. I get the "Conditions Not Met" code now anytime I try to use adaptive cruise. Regular cruise works fine. Genesis is picking her up on Tuesday to look into the issue.
NLJ
261
63
Isn't that error message because you are toggling up instead of down to set it?
