Cruise Control Module
Doc1049
Does repair and reprogramming have to be done at dealership? Found a replacement online for a fraction of cost at dealer. Afraid to R&R if computers will lose memory. Any alternatives?
The scc module is plug and play. When I replaced mine, the startup diagnostics of the car saw the working module, trouble lights did not light up and the cruise worked as it should. Happiness. If you have a return option, what do you have to loose but a few shipping dollars and the labor of the install by your mechanic? Do it.
Dealer claimed entire system would have to be reprogrammed. My mechanic was hesitant to R&R for fear car wouldn't start after replacement because his Snap On guy told him it had to be reprogrammed. Wanted to make sure that it would not affect computer memories. Since the only problem was not being able to use the cruise control I picked up car until I could get more info or results of someone elses experience in switching unit out. Already have replacement. Use car in NJ and will do the switch when I return. They said the same BS before I had HECU switched out. Thanks FloridaGuy.
Apologies. Question already answered. Please disregard.
