Dash Camera and Window Sensors
ifonline
68
Braselton, GA
Genesis G80 Sport
I recently installed a Roav C1 Pro wedge-style dash camera in my 2019 G80 and immediately ran into issues with a partially blocked video due to the gigantic mass of sensors on the windshield. I opted to mount the camera just to the right of the sensor stack as high as possible, because (1) I didn't want the camera to the left as it would be in my view, (2) I didn't want it below the sensor stack because it would be in the way of the sensor on the back of the rear view mirror, and (3) I wanted it as high as possible for the best possible view ahead.
Has anyone else put a dash camera in their G80 with all the sensors on the windshield? If so, do you also get a partially obstructed video? Any suggestions on mounting a wedge-style camera? Would a different style, such as a tube-style like the Blackvue DR750 or a box-style like the Thinkware F800 Pro, be better?
ifonline
68
Braselton, GA
Genesis G80 Sport
Interesting. So, the sensor stack doesn’t impede the camera’s view of the right side of the road or cross traffic from the right? I need to check the lens angle of your camera vs. the C1 Pro. I wonder if mine has a wider lens and, therefore, an easier view to block.
ifonline
68
Braselton, GA
Genesis G80 Sport
The C1 Pro has a lens angle of 145°, and the A119 that you appear to have ranges from 130° to 160°, depending on the version. I wonder if there is enough difference in the angles to matter or if the lens is further from the windshield with the way the C1 Pro mounts. All I know is that the left edge of the video was nothing but black sensor housing and so visibility to the left was poor.
larrymg1
708
191
43
Lexington South Carolina
Genesis G80 Sport
My system is the Street Guardian model: SG9663DC:
SG9663DC Dash Cam Drive Recorder | Street Guardian
https://streetguardian.info/product/sg9663dc
A$488.00 to A$748.00 - ‎In stock
The SG9663DC is a Dual Channel (2 cameras) FULL HD 1080P (both ... Lens: 7 Element, Metal chassis, Glass lens, IR cut, 127° viewing angle; CMOS sensor:
Our cameras have a very similar shape. I can't determine what the cause of your view being blocked on the right side from the center stack.
Please provide pictures of the unit mounted, including a side profile from both sides.
ifonline
68
Braselton, GA
Genesis G80 Sport
I have already taken the camera down as it was unusable. However, it looks like your particular camera has a lens angle of 127º, so I have to believe the angle has something to do with it. I'll keep searching for the right solution.
Thanks.
EdP
Supporting Member
SUPPORTING MEMBER
4,222
1,226
Parrish, FL
gkra
San Diego, CA
Out of curiosity, is there a power tap up there that you can use for installing the power supply for the camera, or are you simply taping the wire around the edge of the windshield to the fuse box on the drivers side of the dash?
