Dead Battery - Can't get into vehicle
shillabr
Edmonton, Alberta, Canada
We have had our 2010 Genesis parked in the garage for several weeks without being started and when we went to unlock the vehicle with the remote fob, it wouldn't unlock. I am assuming that the vehicle battery is dead because neither key fob will unlock the vehicle, even after changing the fob battery. I thought, no problem, I will just use the manual key to unlock it. To my surprise, I found that the key will not work - it will go into the lock but will not turn in either direction. I also tried the manual key in the trunk but in that case the key will not even go into the lock. Now we bought the car used and I am wondering if the previous owner may have changed out the key fobs with new fobs that will work remotely on the car but that don't have the correct keying to be used manually. Is this a possibility?
My dilemma now is how to get into the car (or even the trunk so that I can recharge the battery)? Getting the car to the dealership would be a major ordeal and I am sure that they would not come to me. Does anyone know if tow truck operator can open a Genesis?
EdP
Supporting Member
SUPPORTING MEMBER
5,681
2,339
Parrish, FL
16UltV6Guy
Act as if....
106
52
Jacksonville, FL
I'm not very familiar with the 1st gen Genny, but is there any way to go through the back seat trunk pass-through and manage to reach the emergency trunk open handle?
Or a Pop-a-Lock service should be able to get into the driver's compartment.
Hero6
2
Florida
Locksmith would be the best bet here. In my area, unlocking a car runs about $60 and they are usually there in 45 minutes or less. If you have roadside assistance, your insurance should pay to have this done.
Gunkk
1,399
64
48
Florida
1 more lesson now obvious to the OP: Before you buy a used car, make sure the mechanical key works in the door/trunk locks.
Pedal Commander
