Dealership Service Cost
EdP
Supporting Member
SUPPORTING MEMBER
6,481
3,051
Parrish, FL
EdP
Supporting Member
SUPPORTING MEMBER
6,481
3,051
Parrish, FL
TinsleyC
177
43
Dallas, TX
I just bugs me. They call out a spec that they don't care to meet. The exception (the asterisk) is "if the oil is not available in your country". Well, it IS available in my country - Pennzoil Platinum and Ultra Platinum are good examples.
I made the case to Genesis because they create confusion in their manual. Like I said, I'll likely settle and use the cheap stuff, but if no one ever questions it, they'll never fix it.
EdP
Supporting Member
SUPPORTING MEMBER
6,481
3,051
Parrish, FL
TinsleyC
177
43
Dallas, TX
I thought it was pretty well proven that a full synthetic was better for engines than conventional oil, especially high revving and in cold & hot climates.
Do oil makers even recommend 1 year drain intervals on conventional oil? The manual recommends that too, but again, I think they're assuming you used a full synthetic.
Do it's okay to use conventional oil and drive 7,500 miles and leave it in the engine for a year? I honestly don't know, but it sounds excessive.
EdP
Supporting Member
SUPPORTING MEMBER
6,481
3,051
Parrish, FL
TinsleyC
177
43
Dallas, TX
Okay, I feel better now. I looked up the owner's manual for a 2016 model, and for whatever reason, Hyundai feels that the 2016 Genesis 3.8 should get "GF-4 (or above)" oil, while the Genesis G80 3.8 should get ACEA A5.
But it's the same engine! As Ed discussed, Genesis / Hyundai are just trying to meet top mpg ratings and figure that ACEA oils will help that. So they now call that out for the newer models.
Here's a cut from the 2016 owner's manual.
elp_jc
El Paso, TX
Have a few related questions. First, how many quarts of oil for the G80S 3.3T then? Is it 7.3 like the G70, or 8, like somebody else posted? And is the service for 3 years included on 2020 G80s or not? I don't plan to use it, but need to know to try to negotiate a better deal. Stupid local dealer have messed up my cars EVERY time I had to take them in, so I avoid them like the plague, and do all the maintenance myself. But if I have to pay for service I won't use, I want to discount that. Or try to.
And finally, my ex Azera with the 3.3 started making horrible noises at start-up, due to having the stupid oil filter upside down on top of the engine. If it's still like that, the 3.3T would be a deal-breaker for me. I want it rightside up at the bottom of the engine, even if I have to remove belly pans to get to it. Thank you.
bubbaG80Sport
455
239
43
Genesis G80 Sport
Oil fill is consistently 7.9 Qts. U.S. on my 2018 G80 3.3T Sport. I drain oil for +30 minutes from the lower drain plug and always change the oil filter.
I was surprised at the higher volume, with most cars I've owned being in the 5 qt. range. I suspect the engine oil being used to lube/cool the turbos is the reason for the extra oil. Would be interesting to know what the non-turbo G80 3.8 and 5.0 oil capacity is.
On the 2018 G80 3.3T Sport the oil filter is on the bottom of the engine. I am not convinced top side oil filter is an issue. This was how my 2011 Genesis 3.8 was configured. I put 100K miles on without any issue and it was not noisy. It also made changing the oil filter easy.
What is your hypothesis on the top side oil filter being an issue?
elp_jc
El Paso, TX
Oil drains out of the filter overnight (gravity), even with check valves (not sure the Azera had any). So every time you start the engine cold, it takes precious time before oil pressure builds up and starts lubricating properly. And as you know, the most engine wear happens on cold starts. Anyway, the fact Hyundai changed the location from above to under the engine tells you something :). But glad to hear filter is under the engine now, like it's supposed to. Thanks.
G-769697
Synthetic oil is a scam. I've owned dozens of cars and the oil does not affect anything- never ever had an engine fail due to oil- I'll let the dealer put whatever is appropriate for my climate in my G80 Ultimate.
TinsleyC
177
43
Dallas, TX
Sure, a car will go 30, 40, 100k miles on conventional oil, if you've owned dozens you likely don't drive them all that many miles. It's proven that synthetic oil is superior to conventional oil.
I just want what the manual specifies.
I'm getting mine changed Monday, I'm sure they'll use conventional (the alternate oil) which is fine as long as they'll change it every six months.
GarnetTy1473
241
43
Noblesville, IN
Genesis G90
Yes, maintenance is included on the 2020s. Good luck getting a discount if you don't use it. The dealer gets paid by Genesis to do the maintenance and to valet your car for you. So you doing your own oil changes would actually cost them money. Genesis would be the only one saving money. You're negotiating with a dealer, not Genesis.
EdP
Supporting Member
SUPPORTING MEMBER
6,481
3,051
Parrish, FL
Pedal Commander
