detail info on Garcia Factory's I-one coilover.
GarciafactoryUS
here is spec and photos of our coilover for those people who requested. sorry it took so long time i been so busy and had to translate some of the specs to english.
● 40 levels of dampening adjustability can be set to any preference
● 44mm linear characteristic internal piston
● Italian IP F.A 5W made very high viscosity index guarantees efficient shock-absorbing action at any ambient temperature
● Mono-tube shock design
● Lower bracket height adjustability prevents the needs to adjust the spring perch offering the max shock-absorbing travel
● SAE9254 cold-bent spring is designed to optimize the balance between performance and comfort
* adjustable stabilizer link (on few seleced vehicles only)
* Macpherson strut type suspension includes pillow ball mount with adjustable camber.
* for double wishbone, multi-link type suspension uses specialy aluminum mount.
* some application will be built when ordered.
* Also available custom spring rates and different shock absorber pressure to your like upon request when order.
Progressive springs? Can you provide the spring rates for the Genesis Sedan? Aluminum mounting, what type of metal is used for the threads? Can you provide the weight of the front / rear? Hoping these save off the OEM... Unsprung weight savings is always a plus.
Thanks!
ill try to get those info asap. thx for the interest.
These have camber plates? And how are they adjusted? Room is kind of tight at the top of the suspension
no it has pillow ball mount but no camber plates. camber plates on top only works on macpherson strut type suspenions. for other styles camber plates won't do anything since your suspension arm is still at same angle. Genesis sedan has no camber adjustment for the front. im trying to measure some spec and make something with our office in korea. but as of now there is nothing available even in korea.
How much would this set cost?
Thanks sir!
this is what i got so far...
i'll try to get more detail info.
it takes time since i talk to korea and they talk to factory to get detail info and get back to me.
Front spring in 10kg Rear in 8kg
front upper mount in iron steel
not in aluminium
and also spring rate and gas thickness can be customized to your own specs.
I have a 2010 genny sedan 3.8 my black beauty , just tell me where to by these I-one Coilovers, to me $1500 isn't that much for a product that adds that much change to your vehicle
Try PMing GarciaFactoryUS. He doesn't come on here much anymore but is heavily involved in getting parts from Korea. If you don't hear anything in a few days PM me and I'll give you his other contact info.
Just tell me where & how to get them in my hands & on the car ASAP. is there a US dealer where i can purchase
if i can't get the coil overs i want ,i will go with R-spec shocks w/ ark springs & R-spec rear swaybar. but the unsprung weight advantage of the coilover setup whould be preferred
BC just designed a set for the V8. V6 is available as well.
But I really want those Garcia I-ones, please tell me the supplier over here !!!!
http://genesisowners.com/hyundai-genesis-forum/member.php?u=10650
^ He is the sole supplier, you have to PM him !!!!
However, the real story behind the majority of KDM coilovers is they ultimately come from one actual manufacturer, however this manufacturer supplies many companies who have them painted/powdercoated/anondized all different colors to be "different", but everything that truly matters (Valving, adjustability, spring rate, mounts) is all identical.Funny that pricing on these duplicate coilovers can range anywhere from $600 to $1,500.
