Disable the door chime
WhiteKnight 1130
Peoria, Arizona USA
Well I figured out how to disable the door chime when the car is in ACC with the door open. If you look under the steering column and above the lower dash seal, you'll see a white plug in there. It's position just to the right of the steering column. Simply reach your hand under the dash and unplug this connection. This will disable the chime till you decide to plug it back in again.
