Dome Light needs replacement
JimmyLee
Long Beach, CA
2010 Genesis sedan needs new dome light. I believe it’s called the “ROOM LAMP ASSEMBLY”.
Anyone know where to get a good deal on one? By chance do you know the part number?
Did you ever figure this out? I need a bulb for my 2012 Genesis sedan.
I don't know the part number, but I have replaced the rear done light. Unfortunately the led's are soldered directly into the board so you'll need to order the whole assembly. If you just search up the year of your genesis followed by "genesis dome light" you should see some pop up.
Also, is it for the front or rear assembly? Both are fairly easy to replace, the front might cost ya a bit more though
Front and it is like $365 +/-
2012 and I need the beige color...
I did look on Ebay but maybe I missed it. I don't want to buy a used one that already has a lot of miles from the car it came off. If you see something new, let me know and thanks. I will look again myself.
If it is the front one I bought the whole assembly used on ebay for around $25 a few years ago.
Yes, it is the front and they do have some used ones at a reasonable price. I just believe with 70k miles on the car they were taken out of, they may be ready to quit anytime also.
Not necessarily. Led's are suppose to last longer than standard lighting options.
