Dont switch start just turn on light or audio G80
Rekann
Hellow my genesis g80 2017
Dont switch start just turn on light or audio all just dont start engine in dashbord display not key detection ?
what are you saying?
if the car is not detecting your key, then likely the battery in the key fob is dead, so get a new battery. If you are in the USA, (guessing not from the translated post) then the dealers give the batteries for free if you ask.
until you change the battery, the car will still start if you hold the key right next to the push start button as you press it.
If you can open the key fob without the aid of Navy UDT, you are gifted!
Translation: UDT is Underwater Demolition Team, "Frogman", Seal, ..
Or, like Mr. I says, "the dealer".
thank you
CR2032 Lithium coin cell powers my DH versions. I ordered SONY brand on Amazon, but received counterfeits. I also ordered Voniko 2032s for half the price of the Sony, which had good results in two of my remotes. I check all fob batteries with a voltmeter and a coin cell tester before I put them in the remote fob.
An interesting observation is one of the remotes for the 2016 DH operates the door locks, but still must be pressed to the start switch to start the car.
I intend to replace the battery again after I cook the printed circuit board (PCB) in the toaster oven in an attempt to soften the solder. I have been successful re-soldering Korean PCBs for decades because one bad connection disables the entire function.
