Door mirror dipping
Kempe
When I engage reverse my mirrors don't dip enough, is there any way to adjust them to dip more?
I believe it is saved in the memory options.,
car in reverse with the dip feature enabled, then save the memory setting.
then put car in Drive and be sure it returns the normal setting, if not save again out of reverse.
The only settings are yes and no. Are they going as far as they should? We can't tell from here but if you take a measurement from glass to frame edge or something someone else can check if they are going all the way by comparison.
