The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Got custom downpipes for my G80 sport, I simply bought a set of stinger DPs and had my mechanic to cut them and extend them by about 6 inches, they also have an oxygen sensor so he welded a bung for that, and it sounds glorious 50% louder, I also have a Maintec Exhaust.haven’t had any luck finding downpipes for my g80 sport. Anyone have? G70 or stinger work?
IMR said they are making one, but not sure when they are releasing it.haven’t had any luck finding downpipes for my g80 sport. Anyone have? G70 or stinger work?
I have secondary DPs on my G80 sport, I don't think I will change the primary's just so I don't blow up the turbos.Looks like they actually made them I’m getting my G80 3.3 TT in around a week so I’m doing a little bit of research on the aftermarket since my old 5.0 had almost none![]()
IMR Catless Primary Downpipes G80 3.3L
This is the initial release of the preorder group buy. As of March 15th, products will take 6-8 weeks to be delivered.. We expect to start shipping these by May the first or second week in May. This preorder helps us to purchase purchase raw materials in bulk to for your uniquely designed...www.imramerica.com
Somewhat new to cars, Why would primary downpipes blow the turbos?I have secondary DPs on my G80 sport, I don't think I will change the primary's just so I don't blow up the turbos.
It will eliminate the back pressure causing the turbos to leak oil around the turbine shaft. You can eliminate this bySomewhat new to cars, Why would primary downpipes blow the turbos?
I've had a terrible experience with. IMR so have others buyer bewareIMR said they are making one, but not sure when they are releasing it.
did you have to tune with catless secondaries? will i need anything extra or can i just get a catless secondary downpipe and be fine? bcus i see that for g70s and stingers that there’s no cat on the stock downpipe so all they have to do is replace it with an aftermarket one and they’re fineGot custom downpipes for my G80 sport, I simply bought a set of stinger DPs and had my mechanic to cut them and extend them by about 6 inches, they also have an oxygen sensor so he welded a bung for that, and it sounds glorious 50% louder, I also have a Maintec Exhaust.
No tune is needed with secondary downpipes!did you have to tune with catless secondaries? will i need anything extra or can i just get a catless secondary downpipe and be fine? bcus i see that for g70s and stingers that there’s no cat on the stock downpipe so all they have to do is replace it with an aftermarket one and they’re fine
so it shouldn’t throw any codes either? im not sure if stock g80 downpipes have sensors or not. but i’ve heard that g70 and stingers don’t so being that i would be ordering a downpipe originally made for the g70 or stingers would it cause issues on the g80No tune is needed with secondary downpipes!
Stay away from IMRIMR said they are making one, but not sure when they are releasing it.
