Drag times with the v8...i got it!!!
PINGGOLF
Hartselle, Alabama
Well...I wouldnt say its official...but pretty darn close!
There is an application for the Iphone called DYNOLICIOUS!
You input the make/model and weight and it hits the internet for specs.
You then hit the start button...let it calibrate...and GO when it says go!
Here is my latest time slip and you can see just how accurate it is.
It even tells you when you've had a bad run, your top speed for the run, even your G's!
http://www.dynolicious.com/results/881d6efaffff1c1e7f64375f02388d38.html
Apparently here is what it came up with:
0-60-- 5.67 seconds
1/4 mile-- 13.8 seconds at 109.8 mph.
AND THATS WITH WHEEL SPIN on my BALD Dunlops!!!
People with Iphone's...check it out!
Wow this is really cool. I think my friends T-Mobile phone does a similar feature.
He was in my car as I was driving and he pulled the info off his phone...... My cruise was set at 65mph and his phone matched what the Navi displayed, which was 62mph. Very interesting. He did mention that he uses this on his Honda Repsol 1000cc to get his 0-60 and 0-150 etc.
No way a heavy Genesis is going to run 13.8 in the quarter.........
WAAAAAYYY! Check out motortrends review of the Genesis V8 on youtube. They claim 5.5 to 60 and the 1/4 at 14 secs / 103.7 mph...
Go to about 2:15 on the video
[ame="http://www.youtube.com/watch?v=ochX-BOQrfY"]YouTube - Bargain Benz? 2009 Hyundai Genesis Sedan - Road Test[/ame]
So with .2 milliseconds of difference...I'd say it is pretty accurate!
Heck...if I'm pegging 13.8 in the 1/4 that means it would all boil down to reaction time when it comes to racing the Pontiac G8 GT!!!:eek:
Hmm, not a single suspension comment in that review.
there are lots of tools available on the web.
Car weight 4100 lbs
Power 375 (at the crank).
plug in gear ratios...
the car should deliver 13.5
A question for your drag time, you mentioned wheel spin, had you pulled the fuse on the ECS?
Car weight 4100 lbs
I've seen different lbs on many different sites when reading about the Genesis, but the US Hyundai site claims the following for the V6 and V8 lbs:
Curb weight (lbs.) 3,748 V6 4,012 V8
Car weight 4100 lbs
No, the fuse was in place. It wasnt enough spin to trigger the stability control but the way I feel, is that if I did catch it on the punch I should be able to drop a millisecond or two...therefore, getting close to your 13.5.
It was on the initial surge. bark...bark...bark....bark...PULL
Maybe I should burn the tires before my next pull.
Another thing, had I not just been to the grocery store, it probably would have been even better.
4 cases of cokes, a case of bottle waters, food and a full tank of gas.
It really makes me wonder what this car would do with no passengers, no spare tire, an empty trunk, some good new asphalt, and a gallon or less of gas.
Yeah, this makes me think about how my tire spin would have been if I rememberd to disable the ESC (Which I do each time I get in my car, but somehow forgot) when I made the MagnaFlow Testing video I just posted today. I saw the ESC light up a couple of times up to about 25 mph and felt the rear brakes kick in. It could have been kinda cool if I turned the ESC off and I also was driving over the painted parking lines which reduces traction.
Once the engine has some miles on it and its broken in, it should be stronger and pull better times. No ECS will help as well if you can manage the wheel spin.
Its always fon to see these big cars at drag strips!
Car and Driver Genesis 4.6 test:
Zero to 60 mph: 5.3 sec
Zero to 100 mph: 12.7 sec
Zero to 130 mph: 22.5 sec
Street start, 5–60 mph: 5.7 sec
Standing ¼-mile: 13.8 sec @ 104 mph
Top speed (governor limited): 154 mph
Braking, 70–0 mph: 164 ft
Roadholding, 300-ft-dia skidpad*: 0.84 g
EPA fuel economy, city/highway driving: 17/25 mpg
C/D-observed fuel economy: 21 mpg
Best I've seen for the V6 is in Motortrend:
TEST DATA
Acceleration to mph
0-30 2.0 sec
0-40 3.1
0-50 4.4
0-60 5.9
0-70 7.8
0-80 9.9
0-90 12.4
0-100 15.2
Passing, 45-65 mph 3.2
Quarter mile 14.5 sec @ 96.5 mph
Braking, 60-0 mph 119 ft
Lateral acceleration 0.89 g (avg)
MT figure eight 27.4 sec @ 0.65 g (avg)
Top-gear revs @ 60 mph 1800 rpm
Sorry to rez this thread, but I love their tests [/sarcasm] Look at the 0-100, and then look at the 1/4 mile. They are saying it takes 1.1 seconds to hit 4mph faster?
Btw, Gold Z - a "heavy" genesis not hitting 13.8? My truck weighed 5200 lbs, similar HP (362 rwhp) and snapped 13.7 - so it can be done! I drive with my helmet in the trunk just in case I get an itch to hit the track (5 min from the house)
1.1 seconds to pick up 4 mph at that speed seems reasonable to me. I'm not where I can look it up now, but you could go to one of the mags and see what the 10mph increments are. The faster you go, the longer the increments (DUH).
AHHH, just found that I have a Road & Track with me. Similar performance cars - a 2010 SHO Taurus. 12.8 seconds to 100. 15.6 seconds to 110. That is nearly 3 seconds to pick up 10 mph - so the 1.1 to pick up 4 mph is right in line.
I'll just have to post the timeslips when I finally hit up the track around here. They dumped a bunch of money into it, and I haven't been able to enjoy it yet!
