Driving up a steep driveway
BLT
Hey everytime I try to drive up my drive way (which is steep), my back tires seem to get stuck and just roll in place when i tap on the gas. Of course I do this all cautiously and I try to drive up from an angle cause I don't want to scrape my car which always hurts. Does anyone else get this problem? If so, what do you do?
I've had the same problem on my driveway. Just keep your momentum going by taking it a little faster and you'll be fine.
As a new owner to this new car, I feel hesitant to increase my momentum cause the sound of a car scraping against pavement hurts. But I guess I have to sooner or later huh
My driveway is similar. The sport suspension on my Track model is very stiff and allows one wheel to come off the ground when I turn off the street. I questioned the limited slip differential not working until I did some research on the type of limited slip rear end the car is equipped with from Hyundai. You can do as suggested and go a little quicker or just apply the brake a little bit to make the other rear tire engage and stop spinning. There is a little timing to it, but it will indeed work.
The first time this happened I was caught across a small ditch with one wheel off the ground. We were at a ballgame where you had to park in the grass. One rear wheel would spin leaving me stranded. That was when I wondered why my limited slip was not working. Turns out there must be a little resistance to make the limited slip design work. That is why you can add a little brake to make it work.
Here is a link that explains how it works...
http://en.wikipedia.org/wiki/Torsen
