DRL/Turn Signal Socket Replacement
Des Walton
Like many, I've had frequent blown bulbs in the left front DRL/turn signal. Usually, a quick replacement gives me a temp fix.
This time, I replaced the bulb and it still didn't work. Inspected the socket, and it showed signs of heat damage. The connection appeared okay but it doesn't work.
So, I'm thinking of replacing the socket assembly. Any pro tips on how to do that without removing the entire front headlight. The only video I found online suggested that was a necessary step.
Pretty sure the socket has a connection about 4-5 inches behind it on the wire that you can unplug
I recommend replacing the bulb with LED bulbs in the new socket and add a resister outside of the headlight housing to avoid hyper flashing. This will reduce the heat and the new socket will hopefully give you a better connefction.
