Dual window on 9.2 screen
Kwdan
7
I recently purchased a 2018 G80 ultimate with 9.2 screen. I can't get my "jukebox" to show and I can't do dual screen (Sirius/Nav). I thought I remember reading that I could do it. I've plugged in 3 portable usb drives and system doesn't recognize them. I have music on them. When I purchased car.. software 10.0 was in the system. I have updated to the latest release and I still can't do it.
Don88
♪If You're Ready (Come Go With Me)♫ Staple Singers
SUPPORTING MEMBER
414
126
43
Vancouver WA U.S.
After plugging in the USB, select from the Media button on the dash, "USB Music"; it should play.
Kwdan
7
When I plug it
After plugging in the USB, select from the Media button on the dash, USB; it should play.
In.. system says "USB Device not recognized" so I can't select anything from home/ media
MrMegadeth
532
93
Houston, TX
How is the drive formatted? I use FAT32. Also, maybe you have something weird like a weird directory structure or bit-rate.
The manual tells you everything you need to know about supported formats.
Kwdan
7
It's FAT 32..also tried microSD card in adapter.. regular SD card.. And I had the manual up on my phone while attempting to play/show files. Should my system allow me to have jukebox? Or is that for different (smaller screen)? And how to I get split screen? When I look in settings for nav map size it's greyed out (no adjustment)
EdP
Supporting Member
SUPPORTING MEMBER
7,970
4,184
Parrish, FL
Don't think you can dual screen the 9,2. I never did.
See page 52 and 53 of the DIS manual for a better explanation but this may help:
List
You can view the desired image by searching
the image list included in Jukebox.
1. Press
    Or press [Menu] >
      2. Press the desired image.
      • Press [Menu] > [Now Playing] to move to
      the current playing screen.
      • Press [Menu] > [Delete] to delete the
      desired fi le. For more details, refer to
      “Deleting Address Book” on page 76.
      • Press [Menu] > [Clear Jukebox] to delete
      all fi les and playlists in Jukebox.
      • Press [Menu] > [View Capacity] to check
      the storage capacity saved in Jukebox.
