Easy Access Feature & Lumbar support - need input please
buzz64
Is the Easy Access Feature part of the Tech Option? I have a V6 with the Premium option, but not the Tech option. When I press the Start button to turn off the ignition, the steering wheel slides up, but the seat does not move back. I assume that I do not have the Easy Access Option, but it is not listed as a feature of the Tech package in the brochures. Could someone please enlighten me on what you need to buy to have the Easy Access option. Thanks!!
Also, it appears that my Lumbar support system may not be working properly. I really can't feel any difference when I press the buttons, and one of the buttons (to reduce the lumbar pressure) doesn't seem to work at all. It doesn't even make a noise. Anyone else experience a problem with this? Thanks!
Yes. Easy Access is part of the Tech Package, for Lumbar support checkout page 3-5 of the Owner's Manual
Easy access function
(if equipped)
With the shift lever in the P position, the
system will move the steering wheel forward
and driver’s seat rearward automatically
so you can comfortably enter and
exit the vehicle.
• Without smart key system
- It will move the steering wheel away
from the driver and the driver’s seat
rearward when the ignition key is
removed.
- It will move the steering wheel toward
the driver and the driver’s seat forward
when the ignition key is inserted.
• With smart key system
rearward when the engine start/stop
button is turned to the OFF position.
when the engine start/stop button
is turned to the ACC position.
✽ NOTICE
You can activate or deactivate the easy
access function in the INFO menu of
DIS (Driver Information System, if
equipped) as follows;
• Seat easy access
• Steering easy access
If you want detailed informations, refer
to the DIS manual supplied separately.
