ECU Location 2011 4.6?
Jerziboi
Sorry if this has already been addressed, but I couldn't find anything using search. Is their a DIY to remove the ECU? Or does anyone have pics of where it's located? I'm thinking of swapping it for a tuned BTR Ecu. If you're running a BTR tune are you pleased with the results?
The ECM is located at the driver side underneath the hood, check the attached photo.
  • ECM.pdf
    ECM.pdf
Do you have similar information for the PCM? I need to pull mine have it repaired and replaced. New units have been on universal backorder for over 4 months...
