Electronic Emergency Brake screeching
Ally's Genesis
The Parking Brake May Develop a Screeching Noise or Fail To Release : Land Rover Range Rover Sport Brakes
I recently bought a 2011 Genesis Sedan 4.6. Had to have the electronic emergency brake assembly replaced recently because a 6 inch strip of the emergency/parking brake literally broke off inside the rotor hub. Replaced both rear rotors (to keep it even wear) and the electronic emergency brake assembly was installed by a back yard mechanic friend.
It worked fine for a couple of weeks (use it periodically only) but the other day I parked and turned ON the electronic EBP and I heard a loud screeching sound. I managed to click the EEBP switch to off by pulling up on it TWICE and it stopped the screeching (ie it released).
When I click the EEBP on to now test it- it immediately starts screeching as though “stop” sensor or actuator (?) is no longer functioning. Nothing is signaling the EEBP to stop (since engaged)/ or to tell the car that the EEBP is now in place to hold the brake.
A shop told me they could look at it (next day) but he said it sounds like an issue for a dealership. I want to avoid dealerships.
To summarize, previously when I turned on the EEPB, it would make the regular hum and click noise. But now it’s a hum and SCREECH noise until I disengage it at the lower dash switch.
Please advise.
Thank you.
My 2012 just started doing this also. Any ideas forum family??
My ESC light is on and my brakes are not working so what is the problem
Update :
Dropped my car off at local Hyundai dealer on the 16th, told I had 30+ cars in front of me, followed up several times and slowly moved up the list. Today I called and was told it was just pulled in and informed just the module and cables were 2,133 bucks (WTF)!!!! Was called again to ask permission to proceed with repair, total price with labor to install and program the unit will be 2,643.78. I hope no one has to get this fixed anytime soon because this is crazy expensive on a almost ten year old platform.
