Enjuku Racing - Competition Clutch and Flywheel Combo
Enjuku Racing
IN STOCK!
GENESIS 2.0T
COMPETITION CLUTCH STAGE 2 CLUTCH KIT
This assembly provides an estimated 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 mile break-in REQUIRED with this set-up. (Some kits may not be supplied with all pieces. Please verify with Competition Clutch before ordering).
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, single mass flywheel, all applicable bearings, and the appropriate alignment tool.
COMPETITION CLUTCH STAGE 3.5
This segmented Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up.
The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Kevlar facings, single mass flywheel, all applicable bearings, and the appropriate alignment tool.
