Equus position light or LED accent ring
Tman14
Had the LEDs around the low beam headlight go out on one side. All other lamps work in the headlight assembly. Is there a bulb or known DIY fix available? (2014 Equus)
Hi Equus-ites. Just discovered the same issue with mine. 2011 Signature. The LED ring around the lowbeam is not working on the driver side. Has anyone replaced with OEM parts? What are the after-market options? How labour-intesive or expensive is the replacement work for each option? Thanks.
I have the same problem on my 2011 driver side I was told that it does not have a separate module for the halo ring only for the adaptive headlight Was told that it’s not serviceable that the halo is part of the housing and the whole Headlight would have to be replaced If this is not the case somebody please chime in because I can’t find a decent used headlight that doesn’t have issues on eBay And I’m not willing to spend the money for a brand new headlights for the halo ring
I have this problem with my 2012 Ultimate as well. Is there a relatively easy way to simply disable the lights in the halo ring and not affecting anything else within the headlights? Hopefully without splitting open the lenses...?
Dealer stated the only fix is replacing the headlight assembly...over $1000. No Bueno.
I changed the headlight and I still have the same problem on the driver side only, halo around the low beam and marker are not on, should I contact the dealer to see if they know about the issue?
