Excessive tire wear on my 2015 Hyundai Genesis 5.0 AWD. !!!!Any ideas would be great!!!
GMCGenesisguy
Hello all, I am new here. I've bought a 2015 Hyundai Genesis AWD with the 5.0L. Love the car, but I am having some issues with the rear tires. When I bought it in June, new nitto motivo tires were put on and an alignment was done. I am aware that the rear tires are wider than the front. The mileage was about 70,000km when I bought it. I recently did a tire rotation and noticed that both rear tires had inner edge thread wear to the wires. I was shocked that I was driving with this these dangerous tires for who knows how long. I checked the tires pressure and it was normal. I do mostly highway driving, idk if that is a factor. I dont corner hard either. The front tires looks new, and no sign of uneven wear. Now my car has just over 100,000km on it. Has anyone else had similar issues with their genesis? Is this normal? Any tips would be greatly appreciated. Thanks
snork
10
North NJ
Yeah, that's a tire failure waiting to happen. Needs fixing quick. Looks like camber and alignment issue. Since it's the inside of the tire, when looking at the car from the rear do the tire lean in at the top?
GMCGenesisguy
Sorry for the late reply. Thanks for the inputs. Yes it does lean a little at the top, I'm guessing thats a sign it needs an alignment. I think I have to do alignments every 2-3 month now, because tires are so expensive for this thing. Thats for all the input, I really appreciate it!
GMCGenesisguy
The roads are very bumpy on the highway, that might be a contributing factor to the alignment. I just got my tires replaced from the dealer and they said I need an alignment. So I'm going to get that done within the month or so. Hopefully it the problem goes away.
djohnk
Oklahoma
Same thing happened to me on my 2015 AWD 3.8 ... Inner tire wear on all four. Just used the prorated warranty from Michelin at only 30000 miles. Down to the belt in inner tire and much tread on outer. Had four wheel alignment done at Dealership three days after installing tires and rotated tires as scheduled. Same thing happened on original tires!!
bubbaG80Sport
511
280
63
Genesis G80 Sport
The picture above indicates too much negative camber. If toe was out of spec the wear would be wider/further toward the center of the tire.
You indicate the abnormal wear is the same on both rear tires. This is unusual to see the same wear on 2 tires. Unlikely, but that shop may have a alignment machine out of calibration. I'd take it to another alignment shop. Post your alignment readings here if you have them/can.
More likely it's a rear suspension issue (loose bolts, bent rear suspension/sway bar).
GMCGenesisguy
Thanks for the input guys. I have installed brand new tires and got an alignment done. But 4 month in, and the same thing is happening again. Only happening on the rear tires, the front still have the nitto motivo tires on from when I bought it a year ago. I really dont want to be going through this many tires in such a short period of time. I still have warranty on my car, should I bring it into the dealership?
dareckibmw
Supporting Member
SUPPORTING MEMBER
2,413
690
Romeoville, IL
Genesis G80 Sport
Seejay
7
Houston
It's easy to destroy the rear tires on most v8 luxury cars. I don't intentionally do this, but the torque available from a stop is intoxicating and ...expensive. Driving style is a big factor here. If the OP is a feather foot kind of driver, then something is wrong.
Love2sing
pinawa
2015 Hyundai genesis sedan AWD 5.0 lt with 89, ,200 km . I notice that the rear tires are wore out and replaced them last sept , 2018 with 71,533 km . I've replace the rear tire's will be going on 4 times on the back . And they say there is nothing out on the wheel alignment . Does any one have a similar issue . Thank Fred
EdP
Supporting Member
SUPPORTING MEMBER
7,160
3,550
Parrish, FL
G-578957
I am having a similar problem with my 2015 genesis 5.0 RWD. Rear tires are wearing excessively fast. No problem with front tires. The rears are wearing evenly but slightly more in the middle. I bought the car in Jan. 2019 with about 46,000 miles and new tires on it. I had to replace the rear tires in June due to excessive wear at around 52, 200 miles. I'm now at 56, 000 and the new tires are worn like the previous set. Front tires are in great shape.
Don88
♪If You're Ready (Come Go With Me)♫ Staple Singers
SUPPORTING MEMBER
343
96
Vancouver WA U.S.
ThoughtfulOne
36
Ontario, Canada
The rear tires especially tend to go fast on this car. With fairly fast acceleration, I'm afraid that this is a part of car ownership.
Depending on where you are, you can get deals for tires.
I paid $200 CAD + tax per tire for Continental 275-35 r19 and $225 + tax for 245-40 r19.
Actually in retrospect, I wish I had just replaced the tires with better ones the day I bought the car. The Continentals are not good tires.
jimmy buoy
326
111
43
Sarnia, Ontario, Canada
Ive had similar wear on my rear tires. Had the alignment done and they said it was bang on, but altered it a bit to help with the inside tread wear. According to them the car is setup by the manufacturer to have the best mix of handling and ride. I've seen many other high end RWD with rear tires that seem to tilt inwards at the top of the tire.
Chad86tsi
83
My '15 5.0 was a used car special at a lexus dealer. It had new tires put on that I'm sure were the cheapest they could find (lexani ?), and I have no real reason to believe they even aligned it. 12,000 miles later and I still don't see any real wear to them.
Disclaimer, I drive 98% highway miles. Almost no stop-n-go, very few lights/stop signs. I do have some hard breaking and cornering here and there so I don't baby them though. It's not normal if you are getting this kind of wear with driving under normal conditions.
First real sports car I had many years ago got similar wear as you describe, but it had lowering springs which altered camber, and I drove it harder. I was doing good to get past 12K without the cords showing like yours.
Pedal Commander
