3.3T Exhaust/muffler suggestions?
Pyrosaxplayer
Emperor's Apprentice
California
Looking for suggestions on exhaust brand/products for 2022 3.3t Sport Prestige.
I want a more throaty deeper tone that doesn't wake up 5 blocks.......2 blocks will suffice.
Any issues with keeping the Variable Exhaust intact?
I'm coming from a 07 V6 Mustang with Flowmaster Super44 muffler with a customer oval Exhaust tip. (As you can see, I didn't want to go with anything like the SLP Loudmouth, etc .. even on the mustang.)
Definitely looking for Muffler and Exhaust Tip modification, but flirting with an entire system upgrade
I’ve been searching for exhausts for a little while and it doesn’t seem like there are many options.
Ark Performance makes one and Jun BL has an exhaust with 3 different options for sound/performance. I think the Jun BL exhaust sounds the best but I’m not sure where to order as it comes from Korea.
Search the forum for the Ark “GRiP” exhaust. I think a member here got one and his dyno numbers dropped after install.
Dennis
I have the Jun Bl with EVC on my 2021. Very happy with the sound, a unique tuner-ish sound, the sound clips on their website are pretty accurate. Ordered off of eBay.
Do you have any sound clips? Also how is the drone when cruising?
I'd love to hear it from the inside as well as outside when actually driving. The sound clips that the manufacturer uses are done in a garage, which definitely seem to enhance the aggressiveness of the note.
Dennis
I don't have any sound clips. Drone is really not bad at all, minimal in the mid range when cruising. Best thing is you can close the valves to eliminate the drone. With the valves closed, it literally sounds like a stock exhaust.
Dennis
Perfect, appreciate the info! I'll check that out!
How is the valve controlled? I was looking at the other options as they are a few hundred dollars cheaper. Is the drone bad enough where you want to make it quiet again on long trips?
It's just a mini key fob with a on/off buttons. You can also program it to the buttons on your mirror as well that you would use for your garage opener. You have to run supplied wiring from the valves on the exhaust to the battery in your trunk if your car does not have valves in the stock exhaust. I thought I would close and open them more while I'm driving, but I honestly leave them open 90% of the time. Even my wife, who "hates loud cars" doesn't complain about the drone on trips.
Awesome, thanks so much!
