First little glitch
MichaelOne
FL
When I turned on my 2010 3.8 this morning, the steering wheel didn't "assume the position" as it usually does. I hit the preset button... it didn't move. I fiddled with the control switch... still nothing. The wheel remained in the fully retracted position. After a couple of minutes of driving, I tried the control switch again and this time it worked. At the end of the trip, it returned to the retracted position as always.
Anyone else experience this?
I also have noted that the seat never moves in response to turning it on/off, although it works fine with the control switch and the preset buttons. I don't believe that's normal either... correct?
shifting the gear selector out of P will stop the resume action. So you have to wait til all the setting complete its travel before shifting out of P. belive that will help.
I believe that there is a problem with some genesis. You might want to browse around the forum to find out what to replace. Warranty issue I believe.
I found the thread, thanks. It seems others have had related issues. There's a TSB too.
I also experience the same problem...steering column rarely returns to preferred setting
Where would i find the TSB?
