Flashing open hood symbol in the cluster.
bigpapainscotia
BIGPAPA
NOVA SCOTIA , CANADA
I have a flashing open hood symbol in my cluster ,im guessing it is a sensor , is there any way to turn this off. I check the hood and it is not open. Open to suggestion.
The hood open sensor is at the front right (right if you are seated in the car) of the car. "A" in the picture below. If you disconnect the switch/sensor, it should then read as closed all the time. (Looks like open circuit is hood closed, short circuit is hood open) Alternately, you may be able to adjust it to correct the issue.
thanks will try this
Was driving to Cabela’s and my
Was driving to Cabela’s and had an open hood notification in my cluster as well, saw this post and pulled over and fixed it. Thanks!
Is it possible to post a better picture? I cannot see which part you are pointing to. I'm not a car person. I don't know much about cars. I tried to find the switch but couldn't find it .thanks.
I had the same problem...I started by opening the hood and cleaning all over the place with a strong detergent! (Since I have my car treated against rust every year with a oily coumpound, the dust sticks to the surroundings). After that, the trouble disapeared!
Hi Everyone, What about the 5.0 ? I've been having this alarm going for 3 days now. Can someone help with a solution ?
Should be exactly the same as the 3.8, as far as this issue is concerned.
I finally had to have the latch replaced! A little pin that actuates the sensor was misplaced due to a broken part.
I just cleaned the whole metal piece from around "A" part. It worked!
This is right advice for my car. Fixed! Thank you.
