Fog Lights?
bhill66
Just bought a used 2015 Genesis 3.8 and thought it had fog light from looking at the front but I can not figure out what they are nor find a way to turn them on.
Do you have the original manual?
Not every model had fog lights but if the are, the light stalk has the switch
Front fog lamp (if equipped)
Use the switch next to the headlamp
switch to turn the Fog Lights ON and
OFF. The fog lamps will turn on when
the fog lamp switch (1) is turned to
the ON position after the headlamps
are turned on.
To turn off the fog lamps, turn the
switch to the OFF position.
You can use the fog lamps only when
the headlamps are on low beam.
When the light switch is in the AUTO
position, you can also use the fog
lamps when the headlamps turn on
automatically. The fog lamps will go
OFF when the headlamps turn OFF.
In 2015, I thought only the 5.0 Ultimates had fog lights. They may have been installed by the previous owner as I did when I had my 2015 3.8 Ultimate. I had a switch in stalles inder the dash by my left knee.
are turned on.
I read the manual and see the section talking about the switch but if they are blank lights they look a lot like the pictures of the fog lights in the manual.
