Front turn signals
ccmsmackay
rahway, NJ
Genesis G80 Sport
I have a 2010 genesis 4.6l tech w/ afls. I noticed that the front turn signal bulbs are dual filament bulbs, but they are only turn signal not turn and parking. Just wondering if there was a way to make those bulbs be parking and turn signal. Was going to install a set of led switch back bulbs that are white in parking light and amber in turnsignal.
In the midst of the exact same thing.
From the wiring diagram they show two wires going to each turn signal bulb, being dual filament/dual contact, both of these wires are hot and that it uses a common ground with the rest of the headlamp assembly.
It should be as simple as tapping the DRL wire and one of the turn signal wires together to get it to stay lit with DRLs and then the turn signal switch would take over when commanded.
