Fuel door won't stay closed - How to fix Broken pin on fuel door actuator for 2015 Genesis Sedan
Stumblebum
Pretty sure the pin is broken as the actuator itself works fine. I tried the WD40 quick fix just to make sure, but the unit operates as it should.
I am guessing I closed the door a bit too hard while I was in a hurry. I am hoping someone has figured out a way to lengthen the pin so it will catch the holder. It seems stupid to have to replace the entire actuator because the pin sheared off from closing the door.
Any help would be appreciated.
Dean
