Fuel Mileage
NLJ
680
How often does it decouple and coast at a constant speed? Maybe on a downgrade, certainly not coasting up hill. How much of a difference have you seen in the actual mpg?
Your theory sounds good, but what are the numbers? How much does the rpm change?
The G80 is different. On the G70 you can Coast uphill. You can Coast while passing as well. It deactivates at a certain incline and decline angle.
I can get 6.7L/100km with Eco and only 7.1L/100km on Smart and 7.5L/100km on Comfort!
EdP
Supporting Member
4,512
1,489
Parrish, FL
I assume coasting uphill is to take your foot off the gas and reduce speed..
Translated to US terms that is 35.1, 33.1, 31.3 MPG. I assume those numbers are on the same route and under similar traffic conditions.
Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
1,288
1,252
Portland, OR
We're going on a small road trip this weekend (Sunday) and I'm planning on seeing if I can compare similar stretches of road back to back using sport, vs comfort, vs eco - all without using cruise control, and staying at the same speed.
I'll post my results. It won't be a perfect test by any means, but hopefully it will give us more info.
NLJ
680
Same route. I drive 140km a day round trip for work. All monitored on the return trip. Traffic is the same everyday since it is country roads.
It reduces speed if you let go while going uphill. I normally get past whatever speed I want and Coast down to the minimum speed I want to be at.
Toddasaurus
1,288
1,252
Portland, OR
There ya go. Better MPG in ECO when on country roads. According to your results, over 10% better with ECO vs Comfort!
EdP
Supporting Member
4,512
1,489
Parrish, FL
That is a pretty good difference. I'd still like to see the difference on a highway cruise at a constant speed like you would do on a long trip. With more city driving you may even beat the 10% a bit
Toddasaurus
1,288
1,252
Portland, OR
I'm down with that. Hopefully I can give us additional info on my upcoming trip. Would you like to see the comparison with cruise control on? Or should I just drive the old fashioned way? I'll be doing Comfort vs ECO.
EdP
Supporting Member
4,512
1,489
Parrish, FL
I guess it depends on your foot. CC should take out one factor but it also depends on traffic. The instant read should give an indication though.
If you are on a good flat stretch, I would think if you held the speed with CC, just pushing the button for different modes will change the readout. Easy to do in the flatlands, not so much crossing the Rockies.
ECO will help in driving where you are changing gears and speeds in traffic, but perhaps you can prove what it does or does not do on a cruise in high gear. I know at lower speeds it can change 500 rpm as it will call for a lower gear.
jeffny
4
long Island, ny
My dealer relates that the car does better with smart mode than any other mode. He relates that it learns your driving style and does better gas mileage which seems to hold true for my car, but I'm not sure if it's all BS
orogenesis
26
Oklahoma
I would feel better about being in SMART mode if there was a bit more information from Genesis about what makes it smart and how adaptive it is. For instance does it adapt over multiple trips, or does it reset after every drive?
Soma
Master Bruce!
436
458
63
LA/OC, California
Same. I'm thinking that by that logic it would have some issues if it got used to your regular driving style (aka in traffic for me) but then you throw it a curve ball (someone else drives, you drive more spiritedly, etc)
NLJ
680
It adapts to your driving style and does it fairly quickly.
So before my first service appointment, my Smart profile in terms of aggressiveness was between Eco & Smart. After my service appointment where they updated the ECU and most likely reset everything, it is way more aggressive. Kicks into Smart-Comfort is quicker.
Most likely cause the person that picked up my car drove a little more aggressively on the almost 70km drive back to me. And most likely also cause the ECU was tweaked a bit cause the work order said the update was to improve engine performance!
jeffny
4
long Island, ny
I totally agree but he relayed that it learns my driving style but how?
NLJ
680
i averaged 7.5l/100km (31mpg US) over a 350km road trip this weekend. ~110-125km/h (70-80mph) with a few bursts at higher speed, 4 people plus some gear in trunk, A/C on half the time.
i was impressed to see over 30mpg.
6.6L/100km was the lowest I have had but turned into 6.7L when I stopped to turn into my street.
canucklehead604
one of the few 6MTs...
540
309
63
West Coast Canada
That is pretty impressive! I assume it's 2.0T
^ yes, 6MT 2.0T sport.
gearing seems a bit short for my liking. 100km/h is at ~2250rpm. i'd prefer a touch lower. i was at ~2750rpm @ 125km/h. no issues with droning or excess engine noise, but with the torque on tap i figured longer gearing would be doable.
