G70 2019 - auto dim driving me crazy!
Jaysam613
Hello, any suggestion on turning off auto dim? Or disabling it? Even if it need to cover it!
I can’t tell if there is cops behind me! I
I agree. Mine get so dark I can’t see cars properly. No depth perception
Auto dim what? What are we talking here, mirrors?
You can unplug the connector at the rear view mirror to stop all three from dimming. (Personally, they work great to me, though I am not worried about identifying law enforcement vehicles behind me, for the most part.)
  • Like
Reactions: EdP
Can you provide some information or a link as to the specific location of the connector
Not your mirror, but very similar.
You'd disable all other mirror buttons, like HomeLink and the BlueLink ones, so not smart to do that. A better option would be to block the sensors with black tape. The rear one would be completely invisible. But the front one is somewhere on a corner, at least on my frameless mirror, so it wouldn't look too nice. Maybe the older ones have the sensor in front of the frame, which would be easy. Good luck.
The only sensor to block is the rear facing one (through the mirror glass). Blocking the front facing one would be working counter to what you are trying to achieve (it would cause the mirror to dim). The mirror dims if there is more light coming from behind than in front.
An alternate would be to cut the reverse signal wire and tie it high (connect to switched +12V) going to the mirror. The mirror will not dim if it thinks you are in reverse.
