g70 awd traction control off
namsango
Hello I have g70 3.3t. awd sport in Korea so I'm trying to drift and the output is controlled even if I turn off the traction control in sports mode and sports+ mode. Can't I turn off traction control completely? Are the other North American models different?
Nope its always on even when its off. I believe you have to pull some fuses or get a tune.
What fuse should I pull? Abs? Airbags? I unplugged the four-wheel fuse, but it doesn't work
im not sure on the g70s but the BH guys pull the brake lamp switch(10amp) in the interior fuse box to roast the rear tires. Theres also a fuse under the hood to disable the traction again thats on the BH genesis. If you search on the forums youll be able to find it. The stinger guys also have a way to cut tc
Are you hold the TC button so both TC and stability control are off?
Even when you do that the car will stop itself from getting sideways or burning rubber
Idk I’ve had mine very sideways and spinning tires in the snow. Im pretty sure you can’t do a regular brake stand type burnout without potential damage anyways since it’s awd.
o shit ya your right i didn't realize it was awd
TCU tune or "Brake snip" will allow you to do it. I have some videos of me doing AWD donuts but with the system it just throws all the power to the rear wheels. Im able to get it sideways pretty easily but then again mine is making almost 700lbs of tq :)
I thought the 22-23 models were supposed to include a drift mode? My 2021 goes sideways easily. It is tuned, but even stock I was able to throw it in circles.
