G80 5.0 Trunk issue
elennon62
2015 Genesis, the trunk open indicator light on the dashboard stays on with the trunk fully closed.
My 2015 Genesis, trunk indicator light on dashboard stays on with trunk fully closed
Welcome. Combined both topics, moved it to the second generation Genesis forum and updated the subject so that people who can help you will click through.
Power trunk or manual trunk?
I just resolved a problem with my (power trunk) ajar indicator coming on every time I hit a bump. I did the re-calibrate procedure and it seems to be completely resolved.
How do I do that? I open the trunk and close it and the dashboard open light goes out then comes back on before I move
How do I do that? I open the trunk and close it and the light goes out then comes back on before I move
It only works if you have the power trunk.
Open the trunk all the way. Press and hold the close button on the inside part of the trunk. Quickly press and hold the outside button on the trunk lid. Hold both until after the long tone sounds.
Close the trunk lid manually. Then press the outside trunk button. After it opens all the way, press the close button and it should be set after it closes.
Thank you, I will try that.
