G80 Sport Locks Not Unlocking
NWBrian
Portland, OR
No Genesis Yet!
Hi All,
Second time with this problem: None of the power locks, other than the driver's door, work. The only way to unlock the doors is to flip the switch on each door manually from the inside of the car (unlock button on key doesn't work, unlock button on the driver's side doesn't work, grabbing the door handle from the outside doesn't work, nothing works). This also happened about six weeks ago and, even though it happened 100% of the time and I showed the dealer all the ways I can't unlock 75% of my doors, they claimed to be unable to replicate the problem and returned the car to me with the problem fixed. Six weeks later, it's broken again.
So I'm wondering if anyone has experienced this particular problem or the bizzare way the dealer insisted there wasn't any problem to begin with (remember, this is and was not an intermittent issue and the tech at the dealer couldn't unlock my doors either). I'm bringing my car in again next week for what I hope is the final time for this issue, so any thoughts as to what is going on would be appreciated!
Thanks,
Brian
lt2211
Sustaining Member
348
42
Rockton, Illinois 61072
Hi All,
Thanks,
Brian
Make sure when you stop the car you depress the park button. This will immediately unlock all doors. Check settings in the dash board. Make sure you are set to unlock all doors when placed in park. I am assuming the 2018 G80 Sport has shift by wire but I am not sure. Check that child locks on back doors are not engaged.
NWBrian
Portland, OR
No Genesis Yet!
Thanks It2211. I tried putting the car in park as you suggested and it only unlocked the same one door. Child locks are not engaged.
Mcc
Supporting Member
SUPPORTING MEMBER
3,319
831
Los Angeles
Genesis G90
I can tell you that the back doors are weird. Even with the child locks NOT engaged you still have to manually unlock the back doors or remember to press the unlock on the driver side at least on the G90. Check your settings on the LCD display to see how your door locks are configured. Finally try pressing the unlock on the fob twice from outside the car to see if it unlocks all doors.
With all that being said I cannot think of any reason why grabbing the either front door handles wouldn’t unlock the door. Not sure about the rear doors on the G80 sport but I assume they have the same door grab sensors as the front.
EdP
Supporting Member
SUPPORTING MEMBER
7,975
4,189
Parrish, FL
Yes. All doors can be unlocked.
Automatically Unlock
• Off: The auto door unlock operation will be canceled.
• Power Off: All doors will be automatically unlocked when the Engine Start/Stop button is set to the
OFF position.
• Shift Lever: All doors will be automatically unlocked if the automatic transmission shift lever is
shifted to the P (Park) position.
Two Press Unlock
To activate or deactivate the two press unlock function. If activated, the driver's door will unlock if
the door is unlocked. When the door is unlocked again within 4 seconds, all doors will unlock.
lt2211
Sustaining Member
348
42
OFF position.
Two Press Unlock
I thought this to be the problem also except Brian indicated they did not unlock from the drivers side interior unlock button. That should work in any event or setting.
Mcc
Supporting Member
SUPPORTING MEMBER
3,319
831
Los Angeles
Genesis G90
I agree. There is a serious problem here that only the dealer can handle.
g_768394
Hi All,
Thanks,
Brian
My 2018 G80 Sport is doing the same thing. Did you ever find out what was causing this?
jgibson146
10
7
Atlanta
Genesis G80 Sport
OFF position.
Two Press Unlock
Are you saying a code can be entered to change behavior of unlock feature? Where would I enter this code?
EdP
Supporting Member
SUPPORTING MEMBER
7,975
4,189
Parrish, FL
It is in the menu on the setting. Push the button on the right side of the steering wheel until you get to setting and find the one for door locks. Check the box for the one you want.
olivierhk1
I have exactly the same issue with my G80 Sport. It started today. Did anyone have the answer on how to solve it?
