Gas tank fuel filter
cbpanic
Is it expensive to replace the fuel filter in the fuel tank. It says to replace this every 15k miles or so - 2013 3.8 thanks
Not sure about your 2013, but most cars I’ve been into have the filter built into fuel pump that is mounted in the tank. If your lucky there will be an access hatch under your rear seat on the tank that allows for removal of the whole fuel pump unit. Sometimes fuel gage sender is also built into the unit. Usually it’s not a huge ordeal to remove. You will want to bleed fuel pressure off before removing the fuel line attachment so you don’t spray fuel inside the car. My Infiniti and Mazda had the fuel filter screen built into the pump so it was not a separate unit replaceable by itself. If yours has a separate filter, generally I’ve seen those mounted under the vehicle back by the tank. Just follow the fuel line.
Thank you for that info...a great place to start.
There are my DIY's. You can follow my job. you need to use google website translator.
1) how to replace the fuel pump GENESIS BH: 更换汽油泵 fuel pump
2) the new fuel pump vs the old fuel pump GENESIS BH: 新旧汽油泵对比
3) how to replace fuel pump filter GENESIS BH: 如何更换汽油滤芯
