GDI - I spoke with dealer - they say flush it out every 15,000 miles? What about walnut blast?
john massaria
21
Equus (2011-2016)
GDI - I spoke with dealer - they say flush it out every 15,000 miles? What about walnut blast? Anyone do one or the other at dealer or at mechanic or even on your own? What were your seen Benefits? Risks? Was it Worth it? Thanks! -JM
PMCErnie
Ancient ‘steemed Member
4,452
564
Richmond, VA
What does “flush it out” mean?
john massaria
21
Equus (2011-2016)
I used seafoam to clean GDI right by airflow flap- made huge difference at 50K miles- I did it right before oil change and then did oil change- its suppose to clean the piston heads b/c they see very little if any cleaning from direct injection since it's a Gas direct injection- Hyundai said they wanted $300 my guy said $220 or so- I did it myself for the price of the can and labor- now I can do anytime since I understand the process- it makes idle smoother, shifts faster/smoother and MPG is at least one mile than normal.... I recommend to anyone with GDI engines - its ez peezy!
Alfer
308
63
USA
I've used Seafoam in a few cars. I just pour into gas when tank is near empty then fill up about to half.
What are you doing with the SF?
john massaria
21
Equus (2011-2016)
the fuel additive will not affect the valves - Fuel additives and detergents in gasoline do not help to prevent carbon buildup on the intake valves of a GDI engine. ... GDI engines have a problem that can seriously hurt your customer's vehicle performance and fuel economy, but the solution is fast and easy for you and it's affordable for them.
I copied this from CRC response- but SEAFOAM valvue cleaner will do same-
Conventional multi-point fuel injection injects fuel into the intake tract or cylinder port at low pressure. With gasoline direct injection or GDI a common rail fuel line injects highly pressurized gas directly into the combustion chamber of each cylinder. The improvements in power and fuel economy come from the extremely precise control that GDI engines have over the amount of fuel delivered and injection timing. Fuel and timing are adjusted multiple times per second according to engine load plus, some GDI engines operate on full air intake with no air throttle plate which further improves efficiency and reduces piston pumping losses. Instead of having a throttle plate that restricts the incoming air supply the engine speed is controlled by the ECU and the EMS which regulate fuel injection function and ignition timing but as with many technology advancements there’s also a downside. When conventional multi-point fuel injection injects fuel into the intake tract or cylinder port, gasoline washes over the back sides of the valves. Modern gasoline, with its package of detergents, is an excellent cleaner. So in conventional engines gasoline keeps the back sides of the valves clean and free from deposits, but since GDI engines inject gas directly into the cylinder, gas never reaches the back of the valves. When fuel is no longer washing the intake valves on the way to the cylinder, small amounts of dirt from intake air and blowback carbon from the crankcase inhalation system build up and burn onto the intake walls. The result is carbon deposits forming on the valves, cylinder heads, and injectors, and that’s where the trouble begins. Over time the carbon buildup on the intake valves reduces the air flow to the cylinders, and that reduces torque and horsepower and hurts fuel economy. The carbon deposits on the cylinder in cylinder head can cause pre-ignition, rough starting, and rough idling as well as foul spark plugs and misfire codes. The build-up can become so severe that pieces of carbon can actually break off and burn a hole in the catalytic converter. Many modern GDI engines face a double challenge because they’re variable valve timing keeps the valves open longer to maximize the scavenging effects and minimize emissions that leaves the valves exposed to carbon particles in the cylinder longer and that means more carbon buildup.
How big of a deal is the GDI carbon deposit problem?
It’s big and it’s becoming huge. Gasoline direct injection was actually first invented in 1902 by the French inventor Leon Levavasseur who also produced the world’s first v8 engine, but as of 2008 only 2.3% of passenger vehicles used GDI engines. By 2015, the number was up to 45%. By 2021 roughly 80 million vehicles in the US will have GDI engines, and more cars with GDI engines means more service issues related to carbon deposits and that means more customers who need a solution. Until recently removing carbon buildup on GDI intake valves had been difficult and costly. Labor-intensive processes such as walnut-shell blasting and manual valve cleaning required an engine teardown to access the valves. It was hard work and a very hard sell to many drivers. Before GDI engines became popular, fuel additives were used to treat carbon buildup but with GDI neither the additives nor the fuel would reach the back of the valves. But CRC has an affordable solution that your customers can easily get onboard with. Scientists have found that the chemical polyether amine or PEA, when applied in strong concentration and under the right conditions, can effectively clean hardened carbon deposits from GDI valves and other engine services without blasting brushing or any teardown required. CRC has used this discovery to create a GDI carbon deposits solution that allows you to tackle the problem quickly, easily, and at a very reasonable cost.
CRC GDI IVD intake valve and turbo cleaner is an aerosol spray that’s applied through the engines air intake or throttle body and delivered directly to the backs of the GDI intake valves. CRC GDI valve and turbo cleaner contains the highest concentration of PEA available on the market to provide the fastest, most thorough chemical cleaning available. A single application removes up to 46% of carbon deposits in the first 60 minutes with the ability to clean heavily baked-on carbon deposits the way it does. You might ask, “Is it safe?” Yes CRC GDI valve and turbo cleaner is safe and effective for all gas-powered engines including turbocharged and supercharged engines. It’s safe to use every 10,000 miles or at every oil change and it’s safe to use for 02 sensors and catalytic converters but it should not be sprayed directly on a mass airflow sensor and should not be used in diesel engines. High temperatures can cause carbon to stick to turbocharger turbines, housings, and waste gates. The turbine blades and oil seals are fragile and carbon buildup can eventually cause significant damage but the same cleaning action that removes carbon deposits from valves and pistons cleans turbo impellers as well on turbo engines. CRC GDI valve and turbo cleaner can be sprayed directly through the throttle body or through the air intake but again never directly on a mass airflow sensor.
Okay, here are some real-world independent lab results that prove the effective cleaning power of CRC GDI valve and turbo cleaner. Here’s a 2011 Hyundai Sonata cylinder-head before treatment. Before treatment the carbon deposits average 9.89mm in thickness. You know that’s going to contribute to a tendency for pre-ignition. Now here’s that same cylinder head after an hour of treatment with CRC GDI valve and turbo cleaner. The carbon deposits are nearly gone. The average thickness is down to 1.5mm. The deposits were reduced by 85% after the first hour. Now have a look at the intake valve from the same Sonata after the first hour of treatment. The deposits are reduced by 24%. Take a look at these fuel injectors also from a 2011 Sonata. Before treatment they’re heavily caked with carbon and the flow is being impeded around the injector orifice. After the treatment, the valves look almost new. 100% of flow has been restored and the spray pattern and fuel droplet size are once again optimized for increased fuel economy.
Here’s a cylinder top from a 2009 Cadillac CTS. Carbon deposits average 8.59mm in thickness. After the first hour of treatment the deposits measured 2.77mm, a 68% reduction in deposit thickness. You might wonder why these test results say after the first hour. That’s because the carbon cleaning action will continue for several days after the treatment as the car is driven. Additional carbon that’s been loosened by CRC GDI valve and turbo cleaner is safely removed by the heat and pressure of engine operation. Take a look at these dynamometer results for a 2015 VW Passat 1.8 I4 turbo. The vehicle measured an impressive 5.6 peak wheel horsepower gain two days after treatment, but it picked up an additional 6.9 peak wheel horsepower gain when measured eight days after treatment. Here’s another bonus, CRC GDI valve and turbo cleaner will also work to clean carbon deposits off spark plugs without the need to remove them from the engine. And finally here’s proof that CRC GDI valve and turbo cleaner does really work for turbos. Here’s a 2013 Mini Cooper Countryman turbo impeller before treatment, and here it is after treatment. The results are dramatic. You can see all our test results at CRC Intake Valve Cleaner. The tests are real and so are the results, CRC GDI IVD intake valve and turbo cleaner really does remove tough carbon deposits from valves, piston heads, fuel injectors, and intake manifolds quickly, safely, and without an engine teardown.
First, just as you would with any product, read the entire product label before using so you can understand the instructions and the safety guidelines. Next warm up the engine. CRC GDI valve and turbo cleaner requires a period of heat soak to work, so you want to start with an engine that’s fully warmed up. Locate the throttle body or air intake and spray the product directly through the throttle body. If the throttle body is not easily accessible, spray past the mass airflow sensor but do not spray into the mass airflow sensor assembly. You can also remove the mass airflow sensor assembly and spray where the sensor is mounted. If the vehicle is turbocharged, you can remove the boost sensor and the charge pipe and spray into the pipe. If it’s easier, you can also spray into the vacuum port. Lift the PermaStraw dual action spray system and lock it into place. With the engine running at 2,000 rpm, spray in short bursts until the can is empty. Once the can is empty, rev the engine 2-3 times but don’t exceed 3,500 rpm. Run at idle for one minute then turned the engine off reassemble the air intake system and let the engine heat soak for a full hour. The heat soak is critical, so be patient and let the CRC GDI valve and turbo cleaner do its work. After the hour is up, restart the engine and drive at highway speeds for at least 10 minutes. And remember, as our tests showed the maximum benefit is achieved when the vehicle is driven regularly over the next several days, so let your customer know they should drive the car regularly over the next week or so. If you have a vehicle with severe carbon buildup, CRC GDI valve and turbo cleaner can even be used in successive treatments. Just have your customer drive about a thousand miles before a second treatment in order to get the full benefit of the first treatment.
GDI engines are not the only engines that get carbon deposits. Conventional fuel injected and carbureted engines can suffer from carbon buildup, too. CRC GDI valve and turbo cleaner is safe for use in engines with port fuel injection or carburetors. You can apply the product in the same way as you would on a GDI engine right through the air intake. For automotive service providers, the GDI carbon deposit issue means an expanding service opportunity. Any time a customer comes in for an oil change or a regularly scheduled service suggest treatment with CRC GDI IVD intake valve and turbo cleaner. It’s fast, affordable, and has real benefits for your customers. You’ll be helping to preserve their gas mileage, horsepower, and vehicle life, while adding a nice boost to your sales as well.
Well, that’s it. Thanks for taking the time to learn about CRC GDI IVD intake valve and turbo cleaner. We hope you’ll make it a part of your regular service for your customers with GDI vehicles. We believe they’ll appreciate that you’ve given them an affordable way to preserve their vehicle’s performance and protect their investment.
Husam
15
Where did you spray SF exactly? I'm trying to locate the exact spot or an alternative vacuum line. Thx for the help in advance.
DSXMachina
Just passing through.
149
117
43
Nashua NH
Equus (2011-2016)
I'm both a long time former mechanical engineer, and a mechanic for 43 years. I'm a member of the SAE, the Society of Automotive Engineers. I know something about intake valve deposits in GDI engines.
1. How quickly deposits build up depends on which oil you use. Deposits build up faster with some oils than others.
2. Deposits will build up more quickly as engine oil gets older. More frequent oil changes will result in a slower deposit rate.
3. Oils are being reformulated to deal in part with the GDI problem. An advanced grade is being released in the next few months. It will become available in super low viscosities at first (0W16 and 0W20), but thicker viscosities will follow over subsequent months.
3. Gasolines are being reformulated to reduce deposits. In the meantime use TopTier gasolines. Watch for gasolines advertised to reduce valve deposits.
4. Deposits will build up at differing rates in different climates.
5. Deposits will build up at differing rates depending on how the car is driven.
6. Because deposits affect engine efficiency and emissions, and because manufacturers are on the hook with the Federal Government to meet EPA standards for 5 years and 60,000 miles (or more), a lot of attention is being paid to GDI deposits by OEM engineers all over the world. Half the papers being published by SAE these days seem to concern it in one way or another.
All these variables result in situations where one engine can have significant deposits at 15K miles, and another having virtually no deposits. To just assume your engine needs 'cleaning' can result in needless expense. Deposits need to be confirmed by borescope* inspection, then the proper cleaning method can be determined. IMHO the only effective way to remove deposits is to remove the intake manifold and walnut shell blast the valves (in the closed position with steps taken to ensure no media gets where it shouldn't).
*Done by feeding a 1/4" lens with a powerful light on the end of it down through the intake manifold and into the chambers where the intake valves are.
change741
7
Genesis 2011
Equus (2011-2016)
I have used Seafoam on 1990s era chevys. Works good, gets them to pass emissions when they fail for “high hydrocarbon”. However, when I look at my modern Equus, I am wondering where is the injection location?”
TinsleyC
1,684
724
Dallas, TX
I think that's what we're all wondering - on each specific car, where exactly do you squirt the stuff, and what needs to be removed to get to that spot? Videos of each engine need to be made.
