Genesis Style Wheel Cap Overlays Now Available
Sal Collaziano
Genesis Motors Forum
Staff member
Florida
Cover the Hyundai emblems on your Genesis Sedan with these high quality metal overlays made by LODEN...
genesis-wheel-center-caps-1.jpggenesis-wheel-center-caps-4.jpggenesis-wheel-center-caps-3.jpggenesis-wheel-center-caps-2.jpg
I have after market wheels I'd love to put these on, could you tell me what the dimensions are?
Yes, they're 2 3/8ths of an inch in circumference...
I like them alot
These look fantastic, and at a reasonable cost too!
Just purchased a set of 18” TSW Sebring wheels for my 2016 Genesis Ultimate and am hoping they will fit,near as I can tell the center caps are the mentioned 2 3/8”
Why don't you just remove the TSW caps and swap them with the Genesis ones ?
They are all the same size, 60mm ø. (Industry standard)
My thought is shouldn’t they be left with the original wheels when I attempt to sell them?
Guess I could let the buyer purchase these instead huh!😂
Edit: just tried the Genesis centers caps, guess because it’s a 2016 the center caps are smaller so I can’t switch them with the TSW caps ....bummer!
Back to plan B 😒
But seeing as these are basically peel And stick the good thing is I should be able to simply overlay them to the TSW Caps.
Ok so received my center caps today and have a further question.
I see where they are concaved (pictured ) so see only the edges will actually make contact with the flat surface of my TSW caps. My question is will this be enough of a contact to insure a firm grip and they will not fly off at speed....44946D97-EE8C-435D-A01C-7AABA6696D6E.webpED924B71-94C8-4619-BC63-E1BFD580619E.webp
One other thought,the provided additive , do I wipe this on the back of the new center cap or the face of my TSW cap,
Thanks Larry.
K, mounted the new winged caps now will let them set up for an hour or two and then remount them on the wheels .
Pictures forthcoming!
They should work fine. As long as the wheel center caps (the stock OEM pieces) were cleaned well with alcohol... Dealerships and car washes often get wax or other lubricant-based cleaners on them. Without that stuff being cleaned off, nothing will stick for long. You want to stick each overlay on and hold it in place with a reasonable amount of pressure for sixty seconds each. At that point, there should be no issue. The only thing the manufacturer suggests against is directly power-washing over them.
Bingo!
