Got BBK?
PARTSCOMBINED
No Genesis Yet!
Hello G70 users,
Do you need more stopping power? I want you to check our FELLA BIG BRAKE KIT for your G70.
  • With over 20+ years of experience in the aftermarket automotive manufacturing world, the Fella brand was created in 2016 to focus on high-quality brake component development
  • This G70 Fella Big Brake Kit kit provides shorter stopping distances, better brake modulation, firmer brake pedal feel, and less brake fade when compared to the factory Brembo Kit
  • Fella's Big Brake Kits include a monoblock lightweight 6-piston caliper that is offered in 4 color different options to choose from: RED, BLUE, BLACK, and YELLOW
  • Fella Rotors are 2-piece floating rotors that are designed to reduce heat while also reducing weight
  • Included with the kit are Fella's high-performance signature sport ceramic brake pads that are a perfect match for the G70
  • Fella brake rotors go through an extensive manufacturing process; heat-treated up to 800°C (1472°F) to ensure the rotors can take the punishment from performance driving
  • HEL high-quality reinforced brake hoses are included to avoid vapor locking & corrosion
  • This kit includes premium Fella Floating Rotors for excellent heat dissipation
  • Please allow for 5-7 business days for the kit to be shipped
If you have any questions, don't hesitate to contact me. Thanks.
Interesting.
1. Do you have a front-only kit?
2. What is the minimum wheel diameter that would clear the 380mm disc kit? 19"? 18"?
3. Do the 360mm and 350mm kits use the same 6P caliper and just different mounting bracket?
4. Option for solid discs (non-slotted)?
Hello Volfy,
Thank you for your inquiry. My name is JC, and I am pleased to give you a description of the product.
To answer your questions,
1. We have the front and rear kit. And you can price check below.
2. To install 380 kits, the wheel size should be 19" at least. A 18" should go with 4PS kits, which include 360 or 350 rotors.
3. The 360 and 350 kits use a 4PS caliper. The 360 and 350 are not able to install on the 6P caliper.
4. Yes, we can supply you with solid discs. (A "drilled" is also available)
5. The caliper color can be changed. Let me know your favorite color before you order.
6. You can change the caliper logo. We have another logo.
About FELLA
You can order from me other brake parts such as rotors, pads, hoses, etc.
FRONT 6PMONOBLOCK KIT
REAR 4P 2-PIECE KIT
Hello G70 users,
FRONT FULL FLOATING ROTOR 380*34T
REAR FULL FLOATING ROTOR 380*30T
Thanks for the info. Much appreciate it.
I've got 4 sets of 18" wheels between my Stinger and G70, so I'm not interesting in going to 19's. Sounds like the 6-piston kit with 380mm rotors won't work for me. If I haven't already upgraded to Brembos on my Stinger, your 360mm kit would have been worthy of consideration. I'm not sure how much of a performance upgrade the 360mm kit would be against the Brembos I already have on both cars.
BTW, do you know if your HEL brake hose are direct replacement for the OEM rubber hoses (between body and Brembo calipers)? If so, I would be very interested in just the HEL brake hoses.
