PARTSCOMBINED
- Sep 18, 2022
- No Genesis Yet!
Hello G70 users,
Do you need additional stopping power and instant pedal response? I want you to check our FELLA BIG BRAKE KIT for your G70.
FYI, Ogawa Racing Team visited FELLA KOREA.
I want you to check the link below. (Front 6P Monoblock and rear 4P 2-piece kit)
I am sure, you never regret installing this BBK. 100%
- With over 20+ years of experience in the aftermarket automotive manufacturing world, the Fella brand was created in 2016 to focus on high-quality brake component development
- This G70 Fella Big Brake Kit kit provides shorter stopping distances, better brake modulation, firmer brake pedal feel, and less brake fade when compared to the factory Brembo Kit
- Fella's Big Brake Kits include a monoblock lightweight 6-piston caliper that is offered in 4 color different options to choose from: RED, BLUE, BLACK, BRIGHT GREEN, and YELLOW
- 6P MONOBLOCK BRAKE SYSTEM - Enhanced durability and maximum braking performance
- R4P 2-Piece BRAKE SYSTEM - Enhanced durability and maximum braking performance
- Full floating type 380 * 34T or 360 * 30T a lightweight bracket
- Fella Rotors are 2-piece floating rotors that are designed to reduce heat while also reducing weight
- Included with the kit are Fella's high-performance signature sport ceramic brake pads that are a perfect match for the G70
- Fella brake rotors go through an extensive manufacturing process; heat-treated up to 800°C (1472°F) to ensure the rotors can take the punishment from performance driving
- Various pad compatibility - The wide pad compatibility makes it easy to replace the brake pads
- HEL high-quality reinforced brake hoses are included to avoid vapor locking & corrosion
- This kit includes premium Fella Floating Rotors for excellent heat dissipation
- Can be mounted on the original wheel without a hub-space
- Extending piston - Ensure the best braking force
- Powerful, smooth, and instant response
- CVS Processor (Curve ventilated System Processor)
- Please allow for 5-7 business days for the kit to be shipped
- 18" and smaller than 18" wheels should go with (360mm or 350mm * 30T) applied instead of the 380mm
- 19" and larger wheels applied (380mm * 34T)
- Customers can choose the Caliper colors and logo styles
- Customers can choose the rotor patterns (Slotted or Drilled or Slotted and drilled)
- Our rotors and calipers have received a lot of feedback from customers for +20 years so the item quality has been enhanced and developed
